はじめに
This guide covers the assembly of the Mitsubishi 6G72 DOHC V6 engine (naturally aspirated or twin-turbo). This engine was used in the 1991-1999 Mitsubishi 3000GT/GTO and 1991-1996 Dodge Stealth.
Note: The 6G72 SOHC variant is significantly different in construction despite having the same engine code and is not covered by this guide.
The factory procedure and specifications will be used to assemble the cylinder block, crankshaft, connecting rods, pistons, cylinder heads, valvetrain, and camshafts into what is known as a "long block". If you are using aftermarket or upgraded internal components, please consult your local machine shop or engine builder for the correct assembly specifications for those components.
必要な工具と部品
Use a cylinder hone and drill to prepare the cylinder walls. First clean the walls, then lubricate with diesel fuel or engine oil before honing.
Vary the drill speed and up/down motions to achieve a 30 degree cross hatch pattern on the walls.
Spin the crankshaft one complete rotation. It should spin smoothly throughout.
Attach a dial indicator to the nose of the crankshaft to measure end play.
Use a large flathead screwdriver to carefully move the crankshaft side to side. Zero the indicator at one extreme, then take a measurement at the other extreme.
Install the four girdle side stays.
One stay is shaped differently and goes in the front-right position.
Install the eight side stay bolts. Apply engine oil to the threads and underneath the bolt head.
Use a 14mm wrench to snug all bolts.
Use a torque wrench and 14mm socket to tighten the girdle-side bolts, followed by the block-side bolts.
Install the head gaskets on the cylinder block.
Install heads onto block, being careful the head gasket stays in position.
Install head bolts and hand tighten.
2 の人々がこのガイドを完成させました。
1件のガイドコメント
GREAT info!! My first complete build and I'm NERVOUS!! Still trying to figure out where certain items go.
From my complete gasket kit I can't seem to find info on where the small copper crush washers go and the small O Rings. Would appreciate your info. THANKS!!
Jef Lawlor - 返信 共有
