メインコンテンツにスキップ
Mini Fridge Hinges Replacement
必要な工具と部品
  1. Mini Fridge Hinges Replacement, Hinges: 手順 1、 1の画像 1
    • Remove the plug from the outlet. Be sure to grab from the head of the cord.
  2. Mini Fridge Hinges Replacement: 手順 2、 1の画像 1
    • Remove all food items and shelves from the fridge.
    • Place removed contents to the side and if needed place food items in another fridge temporarily.
  3. Mini Fridge Hinges Replacement: 手順 3、 2の画像 1 Mini Fridge Hinges Replacement: 手順 3、 2の画像 2
    • Remove the cover to the top hinge to access the hinge and screws. If you are unable to remove the cover with your hands, use a flathead screwdriver to pry it off.
    • Remove the three 20 mm Phillips #1 screws from beneath the cover.
  4. Mini Fridge Hinges Replacement: 手順 4、 3の画像 1 Mini Fridge Hinges Replacement: 手順 4、 3の画像 2 Mini Fridge Hinges Replacement: 手順 4、 3の画像 3
    • After removing the top hinge, lift the door off of the bottom hinge.
    • Place the door and removed top hinge securely to the side.
  5. Mini Fridge Hinges Replacement: 手順 5、 2の画像 1 Mini Fridge Hinges Replacement: 手順 5、 2の画像 2
    • Rotate the fridge onto its side.
    • Do not turn the fridge upside down to protect the internal components of the fridge.
    • Remove the two 19 mm Phillips #1 screws and the bottom hinge.
  6. Mini Fridge Hinges Replacement: 手順 6、 1の画像 1
    • Install the bottom replacement hinge and the two 19 mm Phillips #1 screws.
    • Turn the fridge right side up after the bottom hinge is replaced.
  7. Mini Fridge Hinges Replacement: 手順 7、 1の画像 1
    • Place the door on the bottom hinge, aligning the hole with the hinge.
    • Install the new top hinge and the three 20 mm Philips #1 screws. Ensure the orientation of the hinge lines up with the door.
    • Tighten as needed until the fridge door opens and closes normally and is not uneven.
    • Replace the top cover and the shelving inside the fridge.
終わりに
This is a relatively easy fix and is easily repeatable. The replacement parts are inexpensive. We hope this guide extends the life of a mini fridge and expands your understanding of the topic.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Adam Millen
メンバー登録日: 01/29/20
169 ポイント
1ガイドが承認済み
1件のガイドコメント
My fridge is not working Death ho gaya h bikul kuch bbi n chal rha h
Prince Singh - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 29
過去 30 日: 122
今までの合計 5,184
