メインコンテンツにスキップ
Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement
必要な工具と部品
  1. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement, Side Handle Case: 手順 1、 1の画像 1
    • Remove the battery by sliding it from the base.
  2. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 2、 1の画像 1
    • Remove two 20.3 mm screws at the right side of the drill base using a Torx T3 screwdriver.
  3. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 3、 3の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 3、 3の画像 2 Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 3、 3の画像 3
    • Remove five 20.3 mm screws on the right side of the handle using a Torx T3 screwdriver.
  4. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 4、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 4、 2の画像 2
    • Remove four matte 24 mm screws on the crankcase at the rear cover of the drill (connecting the chuck to the handle) using a Torx T3 screwdriver.
  5. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 5、 1の画像 1
    • Remove two 24 mm screws on the housing cover beneath the ventilation slots. These screws point into the drill.
  6. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 6、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 6、 2の画像 2
    • Using a Torx T5 screwdriver bit, remove two 26.8 mm screws on each side of the drill housing cover, located beneath the ventilation slots. These screws point upwards.
  7. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 7、 1の画像 1
    • Gently pry apart the covers for the drill handle.
  8. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement, Dust Cap & Locking Sleeve: 手順 8、 1の画像 1
    • Push down the locking sleeve at the head of the drill.
  9. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 9、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 9、 2の画像 2
    • With the sleeve pushed down, pry off the dust cap.
  10. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 10、 1の画像 1
    • Remove the locking sleeve.
  11. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement, Gasket: 手順 11、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement, Gasket: 手順 11、 2の画像 2
    • Using the iFixit Opening Tool, pry the C-ring off the drill.
  12. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 12、 1の画像 1
    • Remove the ball retaining washer.
  13. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 13、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 13、 2の画像 2
    • Turn the drill so that it points downwards. Push in the ball support plate so that the 7 mm ball falls out.
    • The ball may fall out unexpectedly. Make sure you are attentive and have a clean workspace.
  14. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 14、 1の画像 1
    • Remove the ball support plate.
  15. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 15、 1の画像 1
    • Remove the conical spring.
  16. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 16、 1の画像 1
    • Remove the drill from the side handle case assembly.
  17. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 17、 1の画像 1
    • With the screws removed, gently pry the grey gear housing cover from the rear of the drill.
  18. Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 18、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Gasket Replacement: 手順 18、 2の画像 2
    • Remove the drill from the grey gear housing.
    • Remove the damaged gasket from the crankcase.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Sophie Nieder
メンバー登録日: 02/14/24
820 ポイント
6のガイドは作成済み
チーム
University of Memphis, Team 3-3, Sneed Spring 2024 University of Memphis, Team 3-3, Sneed Spring 2024人のメンバー
UM-SNEED-S24S3G3
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 9
今までの合計 94
