メインコンテンツにスキップ
Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement
必要な工具と部品
  1. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement, Side Handle Case: 手順 1、 1の画像 1
    • Remove the battery by sliding it from the base.
  2. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 2、 1の画像 1
    • Remove two 20.3 mm screws at the right side of the drill base using a Torx T3 screwdriver.
  3. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 3、 3の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 3、 3の画像 2 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 3、 3の画像 3
    • Remove five 20.3 mm screws on the right side of the handle using a Torx T3 screwdriver.
  4. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 4、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 4、 2の画像 2
    • Remove four matte 24 mm screws on the crankcase at the rear cover of the drill (connecting the chuck to the handle) using a Torx T3 screwdriver.
  5. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 5、 1の画像 1
    • Remove two 24 mm screws on the housing cover beneath the ventilation slots. These screws point into the drill.
  6. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 6、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 6、 2の画像 2
    • Using a Torx T5 screwdriver bit, remove two 26.8 mm screws on each side of the drill housing cover, located beneath the ventilation slots. These screws point upwards.
  7. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: 手順 7、 1の画像 1
    • Gently pry apart the covers for the drill handle.
  8. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: 手順 8、 2の画像 1 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: 手順 8、 2の画像 2
    • Locate the forward/reverse shuttle on the drill, just behind the drill trigger mechanism.
    • Gently pull the trigger down and remove the damaged fwd/rev shuttle.
    • Add in the replacement part, ensuring that the shuttle locks into place.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Sophie Nieder
メンバー登録日: 02/14/24
820 ポイント
6のガイドは作成済み
チーム
University of Memphis, Team 3-3, Sneed Spring 2024 University of Memphis, Team 3-3, Sneed Spring 2024人のメンバー
UM-SNEED-S24S3G3
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 65
