はじめに
You can use this guide to replace a damaged cord set on a Milwaukee Reciprocating Saw 6538-21-B36B (2010).
The cord set ensures the correct amount of power is delivered to the saw, allowing the saw to perform its intended tasks. The cord set provides the power necessary to use the saw, if the wires are frayed or damaged it can result in a subpar power supply leading to an unreliable saw with delays. And having a properly functioning cord set ensures there is a proper connection to the power source and the saw, this reduces the electrical hazards and stays in compliance for safety standards. This guide will help you replace the cord so that your device will stay powered!
As always remember to unplug the saw before any replacements. For this replacement just make sure the cord protector is attached to the set before you replace the wires.
必要な工具と部品
Use a TR20 Torx screwdriver to remove the five 15.9 mm screws that secure the two halves of the handle together.
Use a TR20 Torx screwdriver to remove the two 25.4 mm screws near the motor housing.
