メインコンテンツにスキップ
Milwaukee Impact Wrench 9070-20 Motor Field Winding Replacement
必要な工具と部品
  1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 手順 1、 3の画像 1 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 手順 1、 3の画像 2 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 手順 1、 3の画像 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 2、 3の画像 1 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 2、 3の画像 2 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 2、 3の画像 3
    • Remove the four screws on each corner of the gear box assembly using a T-20 Screwdriver.
    • Use a plastic opening tool, slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 3、 3の画像 1 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 3、 3の画像 2 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 3、 3の画像 3
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The motor brushes may need to be compressed to help with the removal of the gearbox assembly.
  4. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 4、 3の画像 1 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 4、 3の画像 2 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 4、 3の画像 3
    • Disconnect the black AC wire from the brown field wire.
    • Disconnect the black field wire from the switch.
  5. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 手順 5、 1の画像 1
    • Pull straight up on the field winding to remove it from the body.
終わりに
作成者
4人の作成者と共同で作成されました。
Brandon Schneiberg
メンバー登録日: 09/26/19
255 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 12
今までの合計 369
