メインコンテンツにスキップ
Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement
必要な工具と部品
  1. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 手順 1、 3の画像 1 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 手順 1、 3の画像 2 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 手順 1、 3の画像 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove (6) 5 x 18mm screws with a T-20 screwdriver.
    • Remove (4) 5 x 14mm screws. with T-20 screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 手順 2、 3の画像 1 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 手順 2、 3の画像 2 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 手順 2、 3の画像 3
    • Hold the device so the gray gearbox assembly faces directly towards you.
    • Remove the four screws with a T-20 screwdriver.
    • After removing all screws, use a small plastic opening tool to slide the gearbox assembly forward.
  3. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 手順 3、 3の画像 1 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 手順 3、 3の画像 2 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 手順 3、 3の画像 3
    • Gently remove the upper clam shell.
    • Slide the motor and gearbox assembly out the front of the device and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The brushes may need to be compressed in order for the motor to be removed.
  4. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 手順 4、 2の画像 1 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 手順 4、 2の画像 2
    • Remove the brushes from the mount by pulling the brush body directly upward.
    • Disconnect the blue wire from the lower brush.
    • Disconnect the white wire from the upper brush.
    • Reconnect the wires to the new brush and replace them back into the mount.
    • The brushes may need to be compressed in order to slide the motor back into position.
終わりに
作成者
4人の作成者と共同で作成されました。
Yuna Choi
メンバー登録日: 09/18/19
387 ポイント
3のガイドは作成済み
チーム
コメント 1 件
Wear to find brushes for impact
Laurie Hathaway-Ashby - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 16
今までの合計 647
