メインコンテンツにスキップ
Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement
必要な工具と部品
  1. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Battery: 手順 1、 2の画像 1 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Battery: 手順 1、 2の画像 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 手順 2、 2の画像 1 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 手順 2、 2の画像 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Brush Block Assembly: 手順 3、 2の画像 1 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Brush Block Assembly: 手順 3、 2の画像 2
    • Remove the two 6mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
  4. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 手順 4、 2の画像 1 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 手順 4、 2の画像 2
    • Pull the motor and brush block assembly out of the drill housing.
  5. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 手順 5、 1の画像 1
    • The gear case is easily separated from the electric motor by gently pulling the two pieces apart.
  6. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 手順 6、 2の画像 1 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 手順 6、 2の画像 2
    • Insert the opening pick between one of the carbon brushes and the electric motor to help compress the spring.
    • While compressing the spring slide that section of the brush block assembly over the bearing.
    • The brush block assembly should easily slide over the bearing now, if it does not repeat the above process as needed for the other three carbon brushes.
終わりに
作成者
4人の作成者と共同で作成されました。
BRYCE DICKERSON
メンバー登録日: 09/05/19
483 ポイント
5のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 23
今までの合計 1,548
