メインコンテンツにスキップ
Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement
必要な工具と部品
  1. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Outer Casing: 手順 1、 2の画像 1 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Outer Casing: 手順 1、 2の画像 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Blade Clamping Mechanism: 手順 2、 1の画像 1
    • Open up the device.
    • Remove the screws that are connecting the shoe to the gearbox using the T15 Torx screwdriver to remove 14.0 mm screws. You will need to pull out the shoe and gearbox to get to the screw on the other side.
  3. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 手順 3、 3の画像 1 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 手順 3、 3の画像 2 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 手順 3、 3の画像 3
    • Using your finger, push the rubber band up to allow you to slide the shoe off of the blade clamping mechanism.
  4. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 手順 4、 3の画像 1 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 手順 4、 3の画像 2 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 手順 4、 3の画像 3
    • Detach the gearbox from the motor.
    • Remove the screws from the gearbox to expose the blade camping mechanism, then pull out the blade clamping mechanism from the gearbox. Use a T15 Torx screwdriver to remove five 14.0 mm screws.
  5. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 手順 5、 2の画像 1 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 手順 5、 2の画像 2
    • Remove the external retaining ring.
    • Next, remove the frontcam.
    • Then, take out the pin.
    • Remove the cam collar.
    • Remove the sleeve.
    • Remove the torsion spring.
    • Lastly, remove the spring cover.
終わりに
作成者
4人の作成者と共同で作成されました。
Mason Jones
メンバー登録日: 09/18/19
572 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G1, Virtue Fall 2019 Western Carolina University, Team S1-G1, Virtue Fall 2019人のメンバー
WCU-VIRTUE-F19S1G1
5 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 26
今までの合計 2,637
