メインコンテンツにスキップ
Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement
必要な工具と部品
  1. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Housing Assembly: 手順 1、 1の画像 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 2、 1の画像 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: 手順 3、 2の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: 手順 3、 2の画像 2
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 4、 2の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 4、 2の画像 2
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 5、 3の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 5、 3の画像 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 5、 3の画像 3
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 6、 2の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 6、 2の画像 2
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 7、 3の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 7、 3の画像 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 7、 3の画像 3
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 8、 2の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 8、 2の画像 2
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 9、 2の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 9、 2の画像 2
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 10、 2の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 10、 2の画像 2
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 11、 3の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 11、 3の画像 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 11、 3の画像 3
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 12、 3の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 12、 3の画像 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 12、 3の画像 3
    • Now pull the reduction gear assembly up and out of the diaphragm.
  13. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: 手順 13、 2の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: 手順 13、 2の画像 2
    • Remove the metal piston from the diaphragm assembly.
  14. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 14、 3の画像 1 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 14、 3の画像 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: 手順 14、 3の画像 3
    • Using a metal spudger, pry the o-ring off of the assembly.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Payton Parker
メンバー登録日: 03/08/19
534 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 UMass Dartmouth, Team S1-G3, Botvin Spring 2019人のメンバー
UMASSD-BOTVIN-S19S1G3
4 メンバー
6のガイドは作成済み
コメント 1 件
to reasemble .
Which is the correct position of the Shift knob assembly ?
Javier Martinez - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 10
今までの合計 1,010
