はじめに
Here is a guide that will show you how to replace the rotor assembly if the grinder isn’t functioning properly. A malfunctioning rotor assembly will cause the grinder to not work properly. The rotor assembly is very important to the operation of the grinder. With tools that work as they should it makes your projects a lot easier.
必要な工具と部品
Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
Using a Torx T20 screwdriver, unscrew the four 6mm screws located at the top of the gearcase assembly.
Pull apart the top of the gearcase assembly to expose the inside of it.
