メインコンテンツにスキップ
Milwaukee 2780-20 Rotor Assembly Replacement
必要な工具と部品
  1. Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: 手順 1、 3の画像 1 Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: 手順 1、 3の画像 2 Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: 手順 1、 3の画像 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 Rotor Assembly Replacement: 手順 2、 3の画像 1 Milwaukee 2780-20 Rotor Assembly Replacement: 手順 2、 3の画像 2 Milwaukee 2780-20 Rotor Assembly Replacement: 手順 2、 3の画像 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 Rotor Assembly Replacement: 手順 3、 1の画像 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 Rotor Assembly Replacement: 手順 4、 3の画像 1 Milwaukee 2780-20 Rotor Assembly Replacement: 手順 4、 3の画像 2 Milwaukee 2780-20 Rotor Assembly Replacement: 手順 4、 3の画像 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: 手順 5、 3の画像 1 Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: 手順 5、 3の画像 2 Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: 手順 5、 3の画像 3
    • Using a Torx T20 screwdriver, unscrew the four 6mm screws located at the top of the gearcase assembly.
    • Pull apart the top of the gearcase assembly to expose the inside of it.
  6. Milwaukee 2780-20 Rotor Assembly Replacement: 手順 6、 2の画像 1 Milwaukee 2780-20 Rotor Assembly Replacement: 手順 6、 2の画像 2
    • Pull the Gearcase Assembly away from the electronic kit.
  7. Milwaukee 2780-20 Rotor Assembly Replacement: 手順 7、 2の画像 1 Milwaukee 2780-20 Rotor Assembly Replacement: 手順 7、 2の画像 2
    • Using a 3/8 wrench, remove the nut located in the center of the Gearcase.
    • The nut and pinion will immediately come apart from the Rotor assembly.
  8. Milwaukee 2780-20 Rotor Assembly Replacement: 手順 8、 3の画像 1 Milwaukee 2780-20 Rotor Assembly Replacement: 手順 8、 3の画像 2 Milwaukee 2780-20 Rotor Assembly Replacement: 手順 8、 3の画像 3
    • Pull the rotor assembly away from the gearcase assembly.
終わりに
作成者
1人の作成者と共同作成されました。
Jimmy Jennings
メンバー登録日: 08/22/19
109 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 895
