メインコンテンツにスキップ
Milwaukee 2780-20 (2) Ball Bearings Replacement
必要な工具と部品
  1. Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 手順 1、 3の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 手順 1、 3の画像 2 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 手順 1、 3の画像 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 2、 3の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 2、 3の画像 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 2、 3の画像 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 3、 1の画像 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 4、 3の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 4、 3の画像 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 4、 3の画像 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 手順 5、 3の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 手順 5、 3の画像 2 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 手順 5、 3の画像 3
    • Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
  6. Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 6、 2の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 6、 2の画像 2
    • Pull the gearcase away from electronic assembly to expose the inside.
  7. Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 7、 2の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 7、 2の画像 2
    • Using a 3/8 Wrench, Remove the nut located in the center of the Gearcase.
    • The nut and pinion should immediatley come apart from the rotor assembly.
  8. Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 8、 3の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 8、 3の画像 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 8、 3の画像 3
    • Pull the rotor assembly apart from the gearcase casing.
  9. Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 9、 3の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 9、 3の画像 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 9、 3の画像 3
    • Using a Torx T15 screwdriver, remove the two 4mm screws to take the bearing retainer off.
  10. Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 10、 2の画像 1 Milwaukee 2780-20 (2) Ball Bearings Replacement: 手順 10、 2の画像 2
    • Use a hammer to knock out the bearing and begin installing the new one before reassembling.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Chris Hopper
メンバー登録日: 08/22/19
468 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 12
過去 30 日: 51
今までの合計 2,987
