はじめに
This guide will display the step-by-step process of fixing and/or replacing a faulty antenna. Soldering may be involved, so be prepared!
必要な工具と部品
First, apply pressure with your thumb on the top of the battery cover.
Next, pull down on the cover until it begins to slide.
Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
5 の人々がこのガイドを完成させました。
