メインコンテンツにスキップ
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
必要な工具と部品
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 手順 1、 3の画像 1 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 手順 1、 3の画像 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 手順 1、 3の画像 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 手順 2、 3の画像 1 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 手順 2、 3の画像 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 手順 2、 3の画像 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 手順 3、 3の画像 1 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 手順 3、 3の画像 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 手順 3、 3の画像 3
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 手順 4、 3の画像 1 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 手順 4、 3の画像 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 手順 4、 3の画像 3
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: 手順 5、 2の画像 1 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: 手順 5、 2の画像 2
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
終わりに
作成者
4人の作成者と共同で作成されました。
Taylor Nesheim
メンバー登録日: 10/11/11
59 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S6G9
2 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,149
