メインコンテンツにスキップ
Microsoft Surface Pro 4 Kickstand Replacement
必要な工具と部品
  1. Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: 手順 1、 3の画像 1 Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: 手順 1、 3の画像 2 Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: 手順 1、 3の画像 3
    • Place your device screen-down on a clean work surface.
    • Place your device on top of a clean cloth, such as a microfiber towel, if you feel the need to protect against scratching.
    • Open the kickstand as wide as it is designed to go (about 135 degrees).
  2. Microsoft Surface Pro 4 Kickstand Replacement, Unscrew the kickstand: 手順 2、 2の画像 1 Microsoft Surface Pro 4 Kickstand Replacement, Unscrew the kickstand: 手順 2、 2の画像 2
    • Use a T5 Torx screwdriver to remove the two 3.3 mm screws securing each hinge to the kickstand.
    • Support the kickstand from behind to prevent damage to the hinges while removing the screws.
    • Do not remove the kickstand yet.
    • The kickstand remains held in place by two flexible appendages between the hinges.
  3. Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: 手順 3、 3の画像 1 Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: 手順 3、 3の画像 2 Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: 手順 3、 3の画像 3
    • Press the kickstand from directly behind the hinges and close it fully.
    • Do not exert force on the kickstand anywhere except for behind the hinges.
    • This step does not apply during reassembly.
  4. Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: 手順 4、 3の画像 1 Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: 手順 4、 3の画像 2 Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: 手順 4、 3の画像 3
    • Pull the kickstand straight out from the bottom of the device.
    • Begin reassembly now before proceeding to steps 5 and 6:
    • Install your new kickstand by inserting its two appendages into the back of the device.
    • Press your new kickstand towards the top of the device until it is fully inserted.
    • Open the kickstand 180 degrees to expose the hinges.
  5. Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: 手順 5、 3の画像 1 Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: 手順 5、 3の画像 2 Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: 手順 5、 3の画像 3
    • To open the hinge, insert your T5 Torx screwdriver into one of the screw holes and gently pry towards the top of your device until the hinge is exposed.
    • Make sure the complete step 4 and begin installing the kickstand first.
  6. Microsoft Surface Pro 4 Kickstand Replacement: 手順 6、 2の画像 1 Microsoft Surface Pro 4 Kickstand Replacement: 手順 6、 2の画像 2
    • Use your fingers or the flat end of a spudger to pry the hinge up into its fully open position.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Sam Omiotek
メンバー登録日: 02/25/19
72,830 ポイント
288のガイドは作成済み
3 件のコメント
Is there a way to fix or replace the hinge? The kickstand on my Surface Pro is fine but the left hinge broke so now it won’t hold it up
Joel Hanson - 返信
Joel - did you find a solution? My left hinge broke a week ago and I’m looking for a solution. Thanks!
Cora Willett -
I’m sorry for the delayed reply. I didn’t check on the hinges when I was working on the guide and unfortunately I don’t have the device still. In my online research, I found that the hinges are replaceable but I wasn’t able to find replacement parts.
Sarah Westberg -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 23
過去 30 日: 107
今までの合計 10,176
