メインコンテンツにスキップ
Microsoft Surface Pro 3 バッテリー交換
必要な工具と部品
  1. Microsoft Surface Pro 3 バッテリー交換, ディスプレイ: 手順 1、 2の画像 1 Microsoft Surface Pro 3 バッテリー交換, ディスプレイ: 手順 1、 2の画像 2
    • 作業を始める前に、バッテリーの残量を25%以下まで放電してください。充電されたリチウムイオンバッテリー は引火の原因となったり、アクシデントで穴を開けてしまうと爆発の恐れがあります。
    • ディスプレイは強力な接着剤で、デバイスのフレームに取り付けられています。
    • ディスプレイを取り外すには、まず接着剤を温めて柔らかくします。ヒートパッド、ヒートガン、iOpenerを使用します。急な時は、ヘアドライヤーでも対応できます。
    • ヒートガンを使用する時は、ディスプレイやバッテリーにダメージを与えないようご注意ください。
    • ディスプレイ周辺全体に均等に熱を温めてます。熱くて触れない程度まで温めます。それから数分間、デバイスが冷えないように温度を保ってください。
    I just replaced both my screen and battery. It took four hours and a couple of wrong turns but I was successful learning what to do next time. However, I am not sure I would do it again.
    It takes more heat than one imagines - all most too much and made me queasy fearing I was going to damage something. I would say it actually too hot and likely to damage something so be careful and do not prolong the removal. To get started I used a glass top warming/buffet heating tray set to about 200 degrees.  I turned the surface pro glass side down before turning it one so it would heat gradually with the tray. I let it heat for 15 minutes. In end, I am not sure it helped or not by starting this way.  This was not an easy removal so I shudder to think how worse it would have been if this didn’t help. I used a variable heat gun for the remaining steps. My screen was broken so breaking it further while nerve racking was not going to be catastrophic.
    michael jones - 返信
    I attempted battery replacement, but during disassembly, i damaged the display by inserting the picks to far, and separating the display circuitry from the glass.
    I used a Milwaukee precision hot tool model 1400, which has only a fixed heat setting, but it worked perfectly to soften the adhesive.
    (I was very careful to heat the entire glass panel by playing the heat gun over the entire surface so that it would expand uniformly.
    Robert Gerlach - 返信
    I just broke mine during the heating process as well…. The glue at the corner was so strong that I cant even slip a blade into the edge… Then when keep applying heat using a hair dryer at low tempreture the glass expanded too much and broke……
    C Y Wong - 返信
    If you have never done this repair, YOU WILL SHATTER THE SCREEN! I've repaired dozens of these over the last several years for my client's and I still shatter them. It's a 98% probability that you will break the glass; it's very thin and shatters easily. Be prepared.
    Gregg Stanley - 返信
  2. Microsoft Surface Pro 3 バッテリー交換: 手順 2、 2の画像 1 Microsoft Surface Pro 3 バッテリー交換: 手順 2、 2の画像 2
    • 吸盤カップもしくはiSclackを引き上げて、メタルフレームとガラスの間にわずかな隙間を作ります。
    • ディスプレイが大きくひび割れている場合、吸盤カップをしっかりと固定できません。まず先にガムテープなどを上に貼ってディスプレイをカバーしてください。あるいは、吸盤カップにスーパーボンドを付けて固めます。
    • 開口ピックをスクリーンとデバイスの間に差し込み、接着剤を切開します。
    • ディスプレイの下側と両側周辺にピックをスライドして、接着剤を切開します。必要に応じて熱を当てて温めてください。
    • ガラスは薄いため、力をいれすぎると簡単に亀裂が入ります。
    • Wi-Fiアンテナは、スクリーン上部端の境目の下に接着剤で固定されています。(カメラの両側)そして、この作業によって簡単に破損してしまいます。スクリーン上部端を剥がす際は、特に慎重に作業を進め、必要に応じて熱を当てて温めます。
    Be very very careful!! Don’t cut yourself. Wear gloves.
    Vincent van Mens - 返信
    Wear eye protection too!
    Zach - 返信
  3. Microsoft Surface Pro 3 バッテリー交換: 手順 3、 3の画像 1 Microsoft Surface Pro 3 バッテリー交換: 手順 3、 3の画像 2 Microsoft Surface Pro 3 バッテリー交換: 手順 3、 3の画像 3
    • 続けてヒートガンでスクリーンのセクションを温めます。
    • ヒートガンでスクリーン周辺の温め作業が終わったら、プラスチックの開口ツールと開口ピックを使って、スクリーンを緩めます。
    • スクリーンは非常に薄く、簡単にダメージを受けてしまいます。壊れたガラスに作業をする際は、ご注意ください。
    I used an inexpensive variable heat gun with a dial. It was perfect. My fixed temperature gun would have ruined it. There are two small vents on either side of the screen near the top. Start there and work down on each side. I didn’t have opening picks to keep the glass separated from the body. So, I used blank Cards Against Humanity I found lying around.
    I watched two popular videos. Neither helped and were no better than these instructions. In one video, the guy heats and smashes his way around the display with metal tool. Mistake! Don’t do this even if the screen is broken. This causes glass shards to go everywhere and will force you to replace the adhesive before installing a new screen. You can’t reuse adhesive if it is full of glass. Another video uses a heat gun one side at a time and simply sliding a pick along the edge working around the Surface. This didn’t work. The person had already removed the screen once before and started the second removal before the video.
    michael jones - 返信
    CAUTION: if you insert the picks too far, you risk damaging the display (separating the glass from the display circuitry).
    The display circuitry is 14 mm from the side edges, 10 mm from the top edge, and 6 mm from the bottom edge.
    Robert Gerlach - 返信
    thanks a lot for your comment
    philrillh -
  4. Microsoft Surface Pro 3 バッテリー交換: 手順 4、 2の画像 1 Microsoft Surface Pro 3 バッテリー交換: 手順 4、 2の画像 2
    • スクリーンを慎重に持ち上げてください。ワイヤが切断しないようご注意ください。
    This guide misses a CRUCIAL NOTE on this step.
    On this step, from Picture 1 to Picture 2 the device is rotated so the Windows logo on the glass is actually on the left hand side.
    You *must* rotate the device otherwise you will risk damaging the cables, as it folds open like a book.
    Len Demby, Jr. - 返信
    Pain in the ass! One has to wonder why they couldn’t use magnetic connections instead of this goo, black thing that even to replace is so %#*@ annoying to say the least! After trying to remove a broken screen I didn’t even use the adhesive strips. I used the ones I had there and to be frank it’s better since:
    a) I couldn’t get the new screen properly aligned and to fit to perfection even though the touch works flawlessly (w/ some adhesive tape on the top to hide the gaps) and
    b) who knows? you may as well need to reopen it again. Hopefully not.Hopefully it will be easier. Hopefully never again!!!
    P.S.:
    Iraklis - 返信
  5. Microsoft Surface Pro 3 バッテリー交換: 手順 5、 2の画像 1 Microsoft Surface Pro 3 バッテリー交換: 手順 5、 2の画像 2
    • バッテリーコネクタを固定している3mm T3トルクスネジを外して、バッテリーコネクタの接続を外します。
    • コネクタの下についている、小さくて長方形のブリッジコネクタを紛失しないようにご注意ください。
  6. Microsoft Surface Pro 3 バッテリー交換: 手順 6、 3の画像 1 Microsoft Surface Pro 3 バッテリー交換: 手順 6、 3の画像 2 Microsoft Surface Pro 3 バッテリー交換: 手順 6、 3の画像 3
    • ディスプレイケーブルを固定している、4mm T3トルクスネジを1本外します。
    • コネクタを持ち上げて、ケーブルの接続を外します。
    • コネクタの下に付いている、小さくて長方形のブリッジコネクタを紛失しないように、ご注意ください。
    It's always best to disconnect the battery before disconnecting the display cable. Ensuring there is no power to the device will also ensure you don't damage the backlight components when disconnecting the display. You should also make sure to reattach the display cable before reattaching the battery cable when putting it back together.
    KCrepairguy - 返信
    There is also a tiny little board between the ribbon cable and motherboard. Be sure not to lose it!!! If you do the part is 1631 LCD Contact Shield Plate.
    Joseph Neilson - 返信
    You’ll notice a spring on the back of your old screen. The new screens don’t have that spring so it will need to be transferred over by the heat gun trick.
    Thierry Plouchart - 返信
    The instructions do not mention the bridge connectors under the connectors - tiny little rectangle boards with gold connector dots. There is one under the battery connector and under the display connector. It is sandwiched in between the board and the connector. You may not even notice the bridge connectors. In fact the pictures here with the cable connectors off are showing the bridge connectors under the cable connectors still lying on the motherboard. Go ahead and remove the bridge connectors with tweezers. These connectors are just lying on the motherboard and WILL FALL OFF getting lost without noticing it. The cable connectors do not work without the bridge connectors installed. Good news is the connectors are keyed and fit only one way.
    BTW: Both screws on the battery and display connector were T3’s and the same size.
    michael jones - 返信
    Hi!. What’s the name of the band connector and what’s the name of the connector in both sides?
    Nicolás Rearte - 返信
  7. Microsoft Surface Pro 3 バッテリー交換: 手順 7、 3の画像 1 Microsoft Surface Pro 3 バッテリー交換: 手順 7、 3の画像 2 Microsoft Surface Pro 3 バッテリー交換: 手順 7、 3の画像 3
    • シルバーのコネクタに接続したオレンジのケーブルを摘みます。
    • コネクタが外れるまで、オレンジのケーブルを慎重に持ち上げます。
    • スクリーンの接続は、これで完全に外れました。
    • 交換用のディスプレイには、インストールに必要なパーツが全て含まれていない場合があります。オリジナルのディスプレイに付いている全てのパーツを保管してください。必要に応じて交換用ディスプレイに移植します。
  8. Microsoft Surface Pro 3 バッテリー交換, バッテリー: 手順 8、 2の画像 1 Microsoft Surface Pro 3 バッテリー交換, バッテリー: 手順 8、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • メタル製スパッジャーを使用して、デバイスのバッテリーを取り外します。
    • かなりの量の接着剤がデバイスにバッテリーを固定していますので、時間をかけてスパッジャーをバッテリーの周りで操作して接着剤をすべて取り除いてください。
    • メタル製スパッジャーは、バッテリーを破裂させる可能性があります。バッテリーを取り外すには、プラスチックカードを使用した方が安全です。
    A plastic card and non-metal spudger were too flexible to work. I used the metal spudger working the outer edge (right and top) getting about half way through these three cells. I then used my hand to pry up at about 60 degrees with a firm slow steady force. The adhesive slowly separated. The batteries were double sided taped to the back of the surface pro. The tape is very thin. It came off with the battery cells and could not be reused. Therefore, I used several lines of Tesa tape for the new battery cells. Make sure the connector on the new battery reaches and fully squares off to the bridge connector on the motherboard. First time I was off by a tiny fraction of an mm. The battery cable has zero give. I had to remove and reset the new battery.
    michael jones - 返信
    The batteries were so strongly adhered by the double face tape, that I ended up using a wooden paint stirrer with the end chamfered into the shape of a chisel (used a razor blade to cut the bevel on the end of the paint stirrer).
    I was able to apply a lot of force using this tool to separate the batteries from the frame.
    Robert Gerlach - 返信
  9. Microsoft Surface Pro 3 バッテリー交換: 手順 9、 1の画像 1
    • バッテリーをデバイスから持ち上げます。
    • 適切な処理のために電池に記載されている指示に従ってください。
    Hello. If I manage to somehow replace the battery, what adhesive should I use to glue the battery and screen back into place?
    reymatt - 返信
    I just used a dot of B-7000 on each of the corners of all four squares of the battery.
    Jared Barneck -
    No way to take the screen off without cracking it PERIOD!!!
    getintouchwitht - 返信
終わりに
デバイスを組み立てるには、分解した手順の逆の順序で行います。
52 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Erik Snyder
メンバー登録日: 10/01/15
5,235 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 12-18, Maness Fall 2015 Cal Poly, Team 12-18, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S12G18
5 メンバー
31のガイドは作成済み
32 件のコメント
Do you have to glue everything back together? Do you heat the parts back up to get the glue to stick again?
Danny O'Boyle - 返信
I slowly removed the old adhesive watching out for glass shards. A spundger and razer blade didn’t really help. In the end, I just used my fingernail and finger to roll the adhesive like I was removing rubber cement. It too about 30 minutes but I was able to get it cleaned off. I replaced the adhesive with 2 mm Tesa tape. This worked great.
michael jones -
Has anyone ever successfully opened a surface pro 3 without breaking the screen?
juliusmalexander - 返信
Yes I have successfully open the surface pro with out breaking the screen by using a heat gun, the islack and the using the picks around the screen as anchors, then use the islack as you will use it to replace the screen in the iphone. It takes time and patience and a lot of heat. It took me 25 minutes to remove the screen with out breaking it.
computertechomar -
Only wizards can accomplish this task without breaking the screen. Yes the screen must be reheated for the glue to stick again. A simple fix to avoid all of these problems is to switch to Apple products.
Erik Snyder - 返信
Apple products are worse. I've worked with Ipads and Iphones and seen my fair share of ballooned batteries that lift the screen off for you.
I successfully removed many screens without cracking by heating to 100 deg with a heat gun, using a small suction cup to lightly tug on the cutting area, using a small syringe to insert alcohol into the adhesive, and using a thin single edge box cutter to slice through the adhesive. The best place to start is at the top near the camera as it's not as sticky there. Make sure your suction cup has a good grip, or you risk cracking the screen if the suction cup lets go with the knife under it.
cpronger12 -
Oh yeh… because Apple products are so easy to change batteries…
tiago_remedio -
This makes no sense at all. Apple products are where almost impossible to fix devices originated.
John Noonan -
Switching to an apple product is not an option.
Mark Wardell -
...but then you have an Apple product. A much worse problem.
Stanley Holmes -
Indeed! Even simpler fix? Live in a cave without technology. However, if the professional tools you need only exist in a Windows environment and you require a stylus and touchscreen, how would Apple's products suffice? As an electrical engineer who uses Altium, DxDesigner, OrCAD, and many other such tools, I'm serious when I ask. Meanwhile, my SP3 is serving me tremendously well.
jimhorn - 返信
With the number of SP3 an SP4s out there, when the time comes that batteries are failing, there will be a market for the service to replace them for under the US$320 that Microsoft charges. A reliable method to do so would be straightforward (a vacuum gripper for the faceplate and body in an 85°C temperature controlled environment) and could be used to reclose and reseal when done. Not hobby grade but would pay for itself with a few days' use to repair Surface Pros. Somebody will step forward to do that...
jimhorn - 返信
Hi, where do I find the details of the battery I need for the replacement?
David Caddick - 返信
You can use the command prompt on Windows 10 for you surface pro 3
1. Press Win+X
2. enter command prompt
3. input the command "powercfg /batteryreport"
4. find the batteryreport on you C:
there is the report of you battery. if you have some question. send Email: CoikVollin@139.com
CoikVollin -
Anyone have weird ripple effect on sides of display after removal and refit? I think I have a loose connector but I cant work out which one it is!
Nick Hine - 返信
320 bucks to replace the battery? That's almost half the price of what I bought this thing for.
neil0808 - 返信
reymatt - 返信
Does anyone know what purpose the little battery board connector serves? Can it be damaged to make the SP3 not power on again?
Lee - 返信
Dunno if you’re around Lee, but I’ve got a Surface Pro 3 not powering and i’d very much like to know the answer! Do you even need that sleeve?
Aaron Moffatt -
This is the bridge connector which sits between the motherboard and the cable connector. It is not held on by anything other than being sandwiched between the motherboard, the cable connector and the screw running through the connectors. It is a must have. The display or battery will not work without their bridge connectors.
michael jones -
This article was a massive help, thanks!
see/read how i ended up doing it here:
https://www.reddit.com/r/Surface/comment...
Carlos Murphy - 返信
Bonjour,
Où peut-on trouver la batterie de remplacement ?
Rony - 返信
As the pictures reveal, this method massively broke the screen. Do NOT use the prying tool to separate the screen. Use something very thin, maybe even an exacto knife, to slip under the screen and work around and separate it. More like slicing than prying. It is still really easy to break it. Make sure it is heated enough and work very SLOWLY.
Barry Hohstadt - 返信
As the pictures show this guy massively busted the screen. Do NOT use the blue plastic prying tool to separate the screen. Use something super thin, maybe even like an exacto knife, to work around the screen more like a slicing action than prying. Even then make sure the glue is sufficiently heated and work very slowly.
Barry Hohstadt - 返信
I know this post is old but I was just wondering, has anyone ever used a heated plate to remove the screen? My Creator Pro 3D printer has a 6” x 9” heated bed that can heated to any desired temperature (up to over 100 degrees Celsius) without running the printer. Putting a fairly thick aluminum plate, with an aluminum “picture frame” on top so the heat only goes to the edges of the screen seems like it might be an easy way to evenly heat the glue to the desired temperature. The question is: what’s the desired temperature to heat the screen?
Thomas Dirrigl - 返信
How wide is the adhesive if I need to replace sections with new adhesive? It look s like the top section is wider than the rest.
scanslers - 返信
Hallo, habe den Akku getauscht. Seitdem funktioniert der Akku nicht mehr. Mein Surface sagt:“Akku nicht gefunden“. Ich kann mein Surface nur mit dem Steomkabel starten. Nach dem Start kann ich das Steomkabel entfernen und er läuft weiter. Was kann das Problem sein?
Mit freundlichen Grüßen,
Kerim A. - 返信
Almost impossible to replace the battery without cracking the LCD screen. In my case, managed to get a hairline crack at the bottom, due to which the touch screen feature has conked off. As it was behaving erratically, simply turned off the HID touch screen in DEVICE MANAGER. And I have my very nippy i7/512GB SSD Surface Pro 3 back again as a very efficient work horse, sans the touch functionality of-course.
The earlier battery had swollen, threatening to crack the screen and more important the risk of a explosion/ fire. Got this great replacement battery on one of my Hong Kong visits and located a smart technician to replace the battery, who charged me just USD 25 for his efforts.
All in all, very happy that got my SP3 functioning back again.
Now next trip, I shall pick up the replacement LCD screen as well.
Glad to know that the Surface range can undergo successful surgery and be functional once again.
jaideepc - 返信
Wow, they were right about being careful not to lose those little bridges between the display/battery cables and the main board. The connections will not work without them! If you finished the replacement and your screen is not working, check if the little bridge is present (step 6, picture 3). At least i managed to find them in the end…
Alex - 返信
my battery went on fire whoe i was slowly heating it for a few minute
Alex Doe - 返信
Replaced the battery since I already needed to replace the screen. Broke screen into many, many pieces. If you're a novice like me, I'd advise against replacing battery if you need an intact screen after you're done until you have some practice.
Very well assembled guide!
Cole Nebeker - 返信
My battery swollen so I think I need to remove it from my SP3… Anyone knows if I don’t replace the battery would the device still work solely on external power? Thanks
C Y Wong - 返信
コメントを追加
統計データ:
過去 24時間: 23
過去 7 日: 207
過去 30 日: 969
今までの合計 175,461
