メインコンテンツにスキップ
Microsoft Surface Pro 2 LCD Display Replacement
必要な工具と部品
  1. Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: 手順 1、 2の画像 1 Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: 手順 1、 2の画像 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 LCD Display Replacement: 手順 2、 1の画像 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 LCD Display Replacement: 手順 3、 1の画像 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 LCD Display Replacement: 手順 4、 3の画像 1 Microsoft Surface Pro 2 LCD Display Replacement: 手順 4、 3の画像 2 Microsoft Surface Pro 2 LCD Display Replacement: 手順 4、 3の画像 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
終わりに
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Mathew B
メンバー登録日: 09/19/16
323 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 6-2, Remmell Fall 2016 USF Tampa, Team 6-2, Remmell Fall 2016人のメンバー
USFT-REMMELL-F16S6G2
4 メンバー
9のガイドは作成済み
4 件のコメント
After replacing the screen my surface will turn on but the screen is just black.... in device manager its showing up as a 'Digital Flat Panel'
yet the screen is still black.. faulty replacement panel???
austin jones - 返信
Same thing happening to me… :(
Marco - 返信
I did this procedure but i dont know why the display is not working it blink and then turnoff can somebody help me how to fix this problem
Smart Instruments - 返信
I purchased a screen replacement (LCD and Digitizer), but apparently, the flex from the motherboard to the screen (the small connector in red as well as the one on the lcd) are missing. Is there a way or place I can purchase just those flex? Or do I need to get a whole new motherboard?
Roselite - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 48
今までの合計 14,439
