メインコンテンツにスキップ
Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement
必要な工具と部品
  1. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement, LCD Assembly: 手順 1、 1の画像 1
    • It's far easier than any other Surface device.
  2. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 2、 1の画像 1
    • From the bottom, carefully pry up the rubber feet on all 4 corners.
  3. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 3、 1の画像 1
    • Using a T5 screwdriver remove the 4 screws on each corner.
  4. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 4、 1の画像 1
    • Make sure the device is completely turned off before proceeding.
  5. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 5、 1の画像 1
    • With the screen open, lift the keyboard out. It doesn't take much force as the part is only held in with magnets once the screws are removed.
  6. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 6、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 6、 2の画像 2
    • Invert the keyboard on itself and remove the unshielded keyboard assembly connector.
  7. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 7、 3の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 7、 3の画像 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 7、 3の画像 3
    • Remove the clip-on shields for the display assembly.
  8. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 8、 1の画像 1
    • Unclip the connectors. They are pretty tight so I'd suggest using a spudger or 2.
  9. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 9、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 9、 2の画像 2
    • Using a T6 screwdriver, remove the 6 screws holding in the display.
  10. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 10、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 10、 2の画像 2
    • Lay the display on a heating pad being careful of the connectors. A heat gun would work too.
    • I used 60 Degrees C for around 15 minutes.
  11. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 11、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Use a metal card to get in between the glass and the housing. Swap to a plastic card to cut through the rest of the adhesive.
  12. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 12、 1の画像 1
    • Watch out for the Sensors up the top. If you damage these the device will fail to turn on. It basically bricks completely without the sensors.
  13. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 13、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 13、 2の画像 2
    • Heat up the bottom of the display and horizontally pull the screen out. Try to leave the bottom adhesive intact as we are going to be using this later.
  14. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 14、 3の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 14、 3の画像 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 14、 3の画像 3
    • Remove one side of the plastic bar holding the cables in place. Slide the display out leaving the plastic bar intact.
  15. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 15、 1の画像 1
    • Screen off. Time to move on.
  16. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 16、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 16、 2の画像 2
    • Remove the snap-on shield and cable. We will need this later.
  17. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 17、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 17、 2の画像 2
    • CAREFULLY loosen the sensor cable on the back of the display.
  18. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 18、 3の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 18、 3の画像 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 18、 3の画像 3
    • Heat the area around the sensors from the front. The adhesive here isn't very strong so you don't need loads of heat.
  19. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 19、 3の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 19、 3の画像 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 19、 3の画像 3
    • Remove the old adhesive and make sure it's clean. You really don't want to be removing this screen once it's set down.
  20. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 20、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 20、 2の画像 2
    • Install the new adhesive. Remove any large clumps on the bottom. We left the old stuff down there as it's a bit awkward to get to cleaning and reapplying-wise.
  21. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 21、 1の画像 1
    • Test the new screen. Make sure you connect the sensors or it won't start or respond at all.
  22. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 22、 2の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 22、 2の画像 2
    • Slide the cable back under the plastic bar and set it back in place. Lightly pull the cables to make sure there's no slack internally.
  23. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 23、 1の画像 1
    • Remove the plastic layer on top of your adhesive and set the screen into the housing. You need to push the screen in quite a bit at the bottom to make it sit correctly.
  24. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 24、 3の画像 1 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 24、 3の画像 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 24、 3の画像 3
    • Place the assembly in then screw it in. Connect the cables and replace the shields.
  25. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: 手順 25、 1の画像 1
    • Install the screws and feet and you're done!
終わりに
Let me know how you got on. I think we can all agree this was much easier than a Book 1… lot less nerve-racking too.
9 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Eric
メンバー登録日: 01/24/17
1,486 ポイント
1ガイドが承認済み
チーム
smashedit.co.nz smashedit.co.nz人のメンバー
Business
9 メンバー
3のガイドは作成済み
2 件のコメント
Real very helpful and very nicely explained
Praveen - 返信
Thanks Praveen
Eric -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 124
今までの合計 8,678
