メインコンテンツにスキップ
Microsoft Surface 2 Screen Replacement
必要な工具と部品
  1. Microsoft Surface 2 Screen Replacement, Screen: 手順 1、 3の画像 1 Microsoft Surface 2 Screen Replacement, Screen: 手順 1、 3の画像 2 Microsoft Surface 2 Screen Replacement, Screen: 手順 1、 3の画像 3
    • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
    • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
    • Avoid touching the metal end of the gun. It will be very hot and can burn you.
    • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
    • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
  2. Microsoft Surface 2 Screen Replacement: 手順 2、 3の画像 1 Microsoft Surface 2 Screen Replacement: 手順 2、 3の画像 2 Microsoft Surface 2 Screen Replacement: 手順 2、 3の画像 3
    • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
    • Use a plastic spudger to pry the retaining clip away from the display cable.
    • The ribbon cable may be glued to the motherboard.
    • Carefully pull the ribbon cable from its socket on the motherboard.
終わりに
21 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
EG1
メンバー登録日: 02/04/16
597 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 3-1, Wollert Spring 2016 USF Tampa, Team 3-1, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G1
4 メンバー
5のガイドは作成済み
9 件のコメント
hello, i try to follow your tutorial, without succes. threre is one cable ribon or three?
sophie delalieux - 返信
This tutorial needs more photos. The part where you unclip the cable from the board is not well illustrated (quite easy to damage the socket by pulling the cable too hard instead of unclamping first)
Matthew Schwantes - 返信
While this guide is essentially effective, it fails to mention one important aspect of the repair. The transceiver board that is mounted to the back of the LCD/Digitizer assembly needs to be transferred to the new screen. It is held in place by three T2 screws, two push clips, and two ribbon cables. This is, of course, in the event the replacement screen doesn’t include the transceiver (everyone I have received doesn’t). Otherwise, it is a great tutorial.
Christopher Janes - 返信
did you figure out how to replace the transceiver board? I am in the same position. When I connect just what the directions say, the screen turns on but had no touch capabilities. But when I connect everything, I have nothing but a black screen. Got any tips?
Bob Burgers -
I have issues with touch capabilities too… any solutions?
Jack Perdue -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 18
過去 30 日: 81
今までの合計 14,961
