メインコンテンツにスキップ
Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement
必要な工具と部品
  1. Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement, Screen: 手順 1、 3の画像 1 Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement, Screen: 手順 1、 3の画像 2 Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement, Screen: 手順 1、 3の画像 3
    • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
    • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
    • Avoid touching the metal end of the gun. It will be very hot and can burn you.
    • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
    • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
  2. Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement: 手順 2、 3の画像 1 Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement: 手順 2、 3の画像 2 Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement: 手順 2、 3の画像 3
    • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
    • Use a plastic spudger to pry the retaining clip away from the display cable.
    • The ribbon cable may be glued to the motherboard.
    • Carefully pull the ribbon cable from its socket on the motherboard.
  3. Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement, Front Facing and Rear Facing Cameras: 手順 3、 2の画像 1 Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement, Front Facing and Rear Facing Cameras: 手順 3、 2の画像 2
    • Work close to Magnetic Project Map to avoid losing screws.
    • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
    • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
    • Once all screws have been removed, lift and remove the bezel from the rest of the device.
  4. Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement: 手順 4、 2の画像 1 Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement: 手順 4、 2の画像 2
    • Use a spudger to pry up the retaining clip covering the camera ribbon cables.
    • The retaining clip may be glued to the motherboard.
    • Use the spudger to flip up the small retaining flap on the zero insertion force connector.
    • Make sure you are prying up on the retaining flap, not the connector itself.
  5. Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement: 手順 5、 3の画像 1 Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement: 手順 5、 3の画像 2 Microsoft Surface 2 Front Facing and Rear Facing Camera Replacement: 手順 5、 3の画像 3
    • Carefully peel away the copper holding the rear-facing camera in place.
    • Carefully pull the rear-facing or front-facing camera from its ZIF connector.
    • No force is needed to plug in or remove the ribbon cable.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Austin Ribickas
メンバー登録日: 02/04/16
150 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 3-1, Wollert Spring 2016 USF Tampa, Team 3-1, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 2,805
