メインコンテンツにスキップ
Microsoft Lumia 640 LTE Headphone Jack Replacement
必要な工具と部品
  1. Microsoft Lumia 640 LTE Headphone Jack Replacement, Back Cover: 手順 1、 2の画像 1 Microsoft Lumia 640 LTE Headphone Jack Replacement, Back Cover: 手順 1、 2の画像 2
    • Use your thumb or fingernail on the edge/corner of the phone to pry the back cover off the phone.
  2. Microsoft Lumia 640 LTE Headphone Jack Replacement, Screen: 手順 2、 3の画像 1 Microsoft Lumia 640 LTE Headphone Jack Replacement, Screen: 手順 2、 3の画像 2 Microsoft Lumia 640 LTE Headphone Jack Replacement, Screen: 手順 2、 3の画像 3
    • Use the tweezers to pull back the sticker, revealing the screw underneath.
    • Be careful when removing the screws as they can strip easily.
  3. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 3、 2の画像 1 Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 3、 2の画像 2
    • Use a T4 Torx driver to remove the screws in the four corners, along with the two in the middle left side (six total).
  4. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 4、 2の画像 1 Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 4、 2の画像 2
    • Using the T4 Torx driver, unscrew the two screws.
    • Keep these screws separate from the screws from back of the phone to ensure that the right screws go where they belong.
  5. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 5、 2の画像 1 Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 5、 2の画像 2
    • Use a plastic opening tool to separate the screen from the back plastic casing
    • Use tweezers to release the clip on the side of device, and remove the back of the phone.
  6. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 6、 2の画像 1 Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 6、 2の画像 2
    • Using the tweezers or a spudger, pull the gold tab up gently.
    • Using tweezers or a spudger, lift the white connector up gently to completely detach the screen from the phone.
    • For motherboard replacement, skip to Step 11 after finishing this step.
  7. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 7、 3の画像 1 Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 7、 3の画像 2 Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 7、 3の画像 3
    • Using a plastic opening tool to carefully get under the gold strip.
    • Use tweezers to pull up the camera.
    • Use tweezers to pull up on the depth sensor.
    • This is held in by a strong adhesive.
  8. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 8、 1の画像 1
    • Use a plastic opening tool to pry up the ear speaker.
    • This is held in by strong adhesive.
  9. Microsoft Lumia 640 LTE Headphone Jack Replacement, Headphone Jack: 手順 9、 1の画像 1
    • Unscrew the 2 remaining screws with the T-4 bit.
  10. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 10、 1の画像 1
    • Use the tweezers to remove the speaker.
  11. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 11、 3の画像 1 Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 11、 3の画像 2 Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 11、 3の画像 3
    • Use the plastic opening tool to lift up the black tab.
    • Use the tweezers to gently pull up on the gold tab.
    • Using the spudger, slowly get underneath the gold sticker and pry it up. This sticker is held down with a strong adhesive.
  12. Microsoft Lumia 640 LTE Headphone Jack Replacement: 手順 12、 1の画像 1
    • Use the tweezers to remove the orange insulator foam.
終わりに
作成者
5人の作成者と共同で作成されました。
Nick Emmert
メンバー登録日: 09/27/18
649 ポイント
5のガイドは作成済み
チーム
Linn Benton Community College, Team S1-G2, Johnson Fall 2018 Linn Benton Community College, Team S1-G2, Johnson Fall 2018人のメンバー
LBCC-JOHNSON-F18S1G2
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 11
今までの合計 414
