メインコンテンツにスキップ
Microsoft Lumia 640 LTE Front Screen Replacement
必要な工具と部品
  1. Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 手順 1、 3の画像 1 Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 手順 1、 3の画像 2 Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 手順 1、 3の画像 3
    • Back comes apart easily
  2. Microsoft Lumia 640 LTE Front Screen Replacement, Peeling of the tape: 手順 2、 2の画像 1 Microsoft Lumia 640 LTE Front Screen Replacement, Peeling of the tape: 手順 2、 2の画像 2
    • Peel the tape from left to the right.
    • Under the tape there is a hidden screw.
  3. Microsoft Lumia 640 LTE Front Screen Replacement, Take out the back screws.: 手順 3、 1の画像 1
    • Take these screws out, and remember organize your screws so you know where they are going when you are putting the phone back together.
  4. Microsoft Lumia 640 LTE Front Screen Replacement, Take out the side screws.: 手順 4、 1の画像 1
    • Turn the phone on its side and there are two (2) more screws that needs to be taken out.
  5. Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 手順 5、 3の画像 1 Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 手順 5、 3の画像 2 Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 手順 5、 3の画像 3
    • Be careful of the top left corner of the phone, the connecting cable is sitting there.
    • The green arrows indicates where the cable is, so be careful
  6. Microsoft Lumia 640 LTE Front Screen Replacement, Disconnect cables: 手順 6、 2の画像 1 Microsoft Lumia 640 LTE Front Screen Replacement, Disconnect cables: 手順 6、 2の画像 2
    • disconnect the two connectors here: Green, and Red.
  7. Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 手順 7、 3の画像 1 Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 手順 7、 3の画像 2 Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 手順 7、 3の画像 3
    • Carefully remove the cable.
    • Top two arrows indicate Camera, and chip. Button arrow indicate the way it is easiest to get the cable off.
  8. Microsoft Lumia 640 LTE Front Screen Replacement, Last step, remove the speaker.: 手順 8、 1の画像 1
    • The speaker comes out really easy
    • Do not fear, it is not attached by a cable but only glue.
終わりに
28 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Nick Johansen
メンバー登録日: 10/09/15
1,991 ポイント
2のガイドは作成済み
18 件のコメント
Guys your awesome. I just replaced a cracked screen and it only cost me the price of a new one.
Ron Hudson - 返信
I'm happy to help, please let me know if there was any step that was hard to understand.
Nick Johansen - 返信
Hi guys microsoft lumia 640 front screen cracked where can i have it replaced plz
Delmark Lawrence - 返信
With the ease of replacing these screens and the availability of the part you could attempt it yourself as it is a simple process and a very rewarding one at that!! :) :p
Cory Hibbin -
thanks nick, do you have a picture of the device without speaker and ready to reassembling?
Labartsara Sara - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 26,198
