メインコンテンツにスキップ
Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement
必要な工具と部品
ビデオの概要
  1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: 手順 1、 2の画像 1 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: 手順 1、 2の画像 2
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 2、 2の画像 1 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 2、 2の画像 2
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 3、 3の画像 1 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 3、 3の画像 2 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 3、 3の画像 3
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: 手順 4、 3の画像 1 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: 手順 4、 3の画像 2 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: 手順 4、 3の画像 3
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 5、 3の画像 1 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 5、 3の画像 2 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 5、 3の画像 3
    • Insert wisdom here.
  6. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: 手順 6、 3の画像 1 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: 手順 6、 3の画像 2 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: 手順 6、 3の画像 3
    • Disconnect the coaxial antenna cable.
    • The cable is attached at several points to the frame and to the board. Gently remove it.
  7. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 7、 3の画像 1 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 7、 3の画像 2 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 手順 7、 3の画像 3
    • The board is glued to the main frame by adhesive tape.
    • Use a hot gun or hair dryer and warm the board.
    • Now you can easy separate the board from the main frame.
    • For the separation process use only plastic tools.
終わりに
16 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
ZFix
メンバー登録日: 12/09/13
192,056 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,525のガイドは作成済み
コメント 1 件
where can i get charging port for microsoft lumia 540
saurabh pawar - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 14,806
