メインコンテンツにスキップ
MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement
必要な工具と部品
  1. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Power off the compressor: 手順 1、 2の画像 1 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Power off the compressor: 手順 1、 2の画像 2
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the compressor is unplugged.
    • Flip the pressure switch lever up to the off position.
  2. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Drain the air from the compressor: 手順 2、 2の画像 1 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Drain the air from the compressor: 手順 2、 2の画像 2
    • Pull the ring on the safety release valve away from the compressor tank to drain the air from the compressor.
    • Ensure all air is drained from the tank before beginning repairs.
  3. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the air hose quick-connect socket: 手順 3、 2の画像 1 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the air hose quick-connect socket: 手順 3、 2の画像 2
    • Use a 3/4 inch wrench to loosen and remove the air hose quick-connect socket.
  4. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the pressure gauge: 手順 4、 2の画像 1 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the pressure gauge: 手順 4、 2の画像 2
    • Use a 7/16 inch wrench to loosen and remove the pressure gauge.
  5. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the regulator: 手順 5、 1の画像 1
    • Use a 5/8" wrench to loosen the air tank nipple from the air tank enough to be able to rotate it with the regulator.
  6. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: 手順 6、 3の画像 1 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: 手順 6、 3の画像 2 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: 手順 6、 3の画像 3
    • Rotate the regulator 180°, so the bottom of the regulator faces away from the compressor motor.
  7. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: 手順 7、 3の画像 1 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: 手順 7、 3の画像 2 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: 手順 7、 3の画像 3
    • With a 5/8 inch wrench bracing the air tank nipple, use a 3/4 inch wrench to loosen and remove the regulator.
    • Make sure the nipple stays connected to the air tank.
    • During reassembly, tighten the air tank nipple to the air tank, and then tighten the regulator to the nipple.
終わりに
作成者
1人の作成者と共同作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
198,503 ポイント
416のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 145
