メインコンテンツにスキップ
Mi-T-M Heater MH-0190-0M10 Ignitor Replacement
必要な工具と部品
  1. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Safety precautions: 手順 1、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Safety precautions: 手順 1、 2の画像 2
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the upper shell: 手順 2、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the upper shell: 手順 2、 2の画像 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
  3. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 3、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 3、 2の画像 2
    • Lift the upper shell straight up off of the machine to remove it.
  4. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the right-side cover: 手順 4、 1の画像 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  5. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 5、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 5、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 5、 3の画像 3
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display before you press the cover into place.
  6. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 6、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 6、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 6、 3の画像 3
    • There are two wires connecting the power switch to the main PCB assembly.
    • Use needle nose pliers to remove the wire with the blue connector.
    • Remove the wire with the clear connector.
    • Remove the right-side cover.
    • During reassembly, install the power switch wires back in their original locations with the blue wire above the clear wire.
  7. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ground wires: 手順 7、 1の画像 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the screw securing the two green ground wires to the frame.
  8. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: 手順 8、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: 手順 8、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: 手順 8、 3の画像 3
    • Use a pair of needle nose pliers to release the hose clamp from the fuel line.
    • Slide the hose clamp off of the nipple, about one inch down the fuel line.
  9. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 9、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 9、 2の画像 2
    • Pull to disconnect the fuel line from the motor and pump assembly.
  10. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 10、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 10、 2の画像 2
    • Use a pair of needle nose pliers to remove the fuel line hose clamp.
  11. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the motor and pump assembly: 手順 11、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the motor and pump assembly: 手順 11、 2の画像 2
    • Use a pair of needle nose pliers to disconnect the wires connecting the motor and pump assembly to the main PCB board:
    • One red cable labeled MOTOR 2 on the main PCB board
    • One orange cable labeled MOTOR 1 on the main PCB board
    • Pull the wires with the needle nose pliers by their connectors and not the wires themselves.
  12. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 12、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 12、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 12、 3の画像 3
    • Use a pair of flush cutters to cut the cable tie harnessing the wires running from the main PCB assembly.
    • Remove the cable tie.
    • During reassembly, install a new cable tie.
  13. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 13、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 13、 2の画像 2
    • Use a pair of flush cutters to cut the cable tie harnessing the orange, red, white, and black wires near the fuel line.
  14. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 14、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 14、 2の画像 2
    • Use a pair of flush cutters to cut the cable tie harnessing the orange and red wires next to the motor.
  15. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Detach the capacitor: 手順 15、 1の画像 1
    • Use a Phillips screwdriver to remove the screw securing the capacitor band clamp.
  16. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 16、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 16、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 16、 3の画像 3
    • Remove the capacitor from the band clamp.
    • During reassembly, realign the foam padding between the capacitor and the band clamp.
  17. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: 手順 17、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: 手順 17、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: 手順 17、 3の画像 3
    • Feed the orange and red wires out through the opening in the lower shell.
  18. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 18、 1の画像 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the left-side cover.
  19. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 19、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 19、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 19、 3の画像 3
    • Remove the left-side cover.
  20. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 20、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 20、 2の画像 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four screws securing the motor mount bracket, two on each side.
  21. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 21、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 21、 2の画像 2
    • Lift the motor, pump, and bracket assembly straight up out of the machine.
  22. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: 手順 22、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: 手順 22、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: 手順 22、 3の画像 3
    • Grab the spark plug wires by their boots and pull firmly to disconnect them from the spark plug.
  23. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 23、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 23、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 23、 3の画像 3
    • Feed the wires through the opening in the lower shell.
  24. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: 手順 24、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: 手順 24、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: 手順 24、 3の画像 3
    • Use a pair of needle nose pliers to depress the locking tab on the red wiring harness's connector labeled IG on the main PCB assembly.
    • With the locking tab depressed, pull to remove the red wire from its header on the PCB.
  25. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: 手順 25、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: 手順 25、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: 手順 25、 3の画像 3
    • Use your fingers to bend the metal tab on the lower shell holding the igniter in place upward to create space for the igniter to be removed.
    • During reassembly, bend the tab back into place once the new igniter is installed.
  26. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 26、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 26、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 26、 3の画像 3
    • Lift the igniter out from underneath the lower shell.
  27. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 27、 2の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 27、 2の画像 2
    • Feed the red wire harness through the opening in the lower shell.
  28. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 28、 3の画像 1 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 28、 3の画像 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: 手順 28、 3の画像 3
    • Remove the spark plug wires from underneath the lower shell.
    • Remove the igniter.
終わりに
作成者
1人の作成者と共同作成されました。
Sam Omiotek
メンバー登録日: 02/25/19
84,838 ポイント
290のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 267
