メインコンテンツにスキップ
Meta Quest 3 Controller Strap Replacement
必要な工具と部品
  1. Meta Quest 3 Controller Strap Replacement, Controller straps: 手順 1、 1の画像 1
    • First, you will want to pick up any of the controllers to begin replacing the wrist strap.
  2. Meta Quest 3 Controller Strap Replacement: 手順 2、 1の画像 1
    • Adjacent to the controller's joystick is a white triangle button.
    • You need to press down firmly on the button to open the controller's battery compartment.
  3. Meta Quest 3 Controller Strap Replacement: 手順 3、 2の画像 1 Meta Quest 3 Controller Strap Replacement: 手順 3、 2の画像 2
    • Once you open the compartment, pinch and pull up the strap to disconnect it from the controller.
  4. Meta Quest 3 Controller Strap Replacement: 手順 4、 1の画像 1
    • Grab the corresponding wrist strap for the controller you are working on.
  5. Meta Quest 3 Controller Strap Replacement: 手順 5、 2の画像 1 Meta Quest 3 Controller Strap Replacement: 手順 5、 2の画像 2
    • With the new wrist strap, push the black clip down into the now-empty small compartment to connect your new strap to the controller.
  6. Meta Quest 3 Controller Strap Replacement: 手順 6、 2の画像 1 Meta Quest 3 Controller Strap Replacement: 手順 6、 2の画像 2
    • You can close the battery compartment using the new cover connected to the controller strap.
    • Closing the battery compartment can be frustrating because it is connected to the strap; I found it easier to slide the cover from the bottom to the top.
    • The new controller straps come with new battery compartment covers, so when you replace the straps, you will end up with spare parts.
  7. Meta Quest 3 Controller Strap Replacement: 手順 7、 3の画像 1 Meta Quest 3 Controller Strap Replacement: 手順 7、 3の画像 2 Meta Quest 3 Controller Strap Replacement: 手順 7、 3の画像 3
    • Put the controller in your hands to see if you need to adjust the fit of the strap.
    • If Adjustments are needed, you can pull or push the strap through the clip's hole.
  8. Meta Quest 3 Controller Strap Replacement: 手順 8、 2の画像 1 Meta Quest 3 Controller Strap Replacement: 手順 8、 2の画像 2
    • Next, repeat steps 2-7 on the second controller.
    • As mentioned in step 6, you will have spare parts left over from the original wrist strap and battery cover. Store these parts somewhere safe if you ever feel like reverting to the original controller straps.
終わりに
Once you have followed all these steps, you will have properly applied the accessory to your oculus quest 3 controllers.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Andrew28709
メンバー登録日: 10/18/23
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 3-17, Briggs Fall 2023 CSU Los Angeles, Team 3-17, Briggs Fall 2023人のメンバー
CSULA-BRIGGS-F23S3G17
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 37
過去 30 日: 196
今までの合計 1,664
