メインコンテンツにスキップ
MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement
必要な工具と部品
  1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: 手順 1、 2の画像 1 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: 手順 1、 2の画像 2
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 2、 1の画像 1
    • Slide the battery cover off in the direction of the arrow on the cover.
  3. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 3、 2の画像 1 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 3、 2の画像 2
    • Remove the batteries (2 AA).
  4. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 4、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 5、 2の画像 1 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 5、 2の画像 2
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 6、 2の画像 1 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 6、 2の画像 2
    • Lift the metal tab until it is straight and can move through the slot in the battery compartment.
  7. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 7、 2の画像 1 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 手順 7、 2の画像 2
    • Flip the remote controller to the external side and slide the metal connections in the battery compartment straight up.
    • Slide the new connections straight down into the slot in the battery compartment, flip to the internal side, and bend the metal tab until it's parallel with the battery compartment.
終わりに
作成者
3人の作成者と共同で作成されました。
Monica Reece
メンバー登録日: 08/31/18
672 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G3, Virtue Fall 2018 Western Carolina University, Team S1-G3, Virtue Fall 2018人のメンバー
WCU-VIRTUE-F18S1G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 200
