メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver. Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Using your hands, gently pry the top and bottom of the projector casing apart. Using your hands, gently pry the top and bottom of the projector casing apart.
    • Using your hands, gently pry the top and bottom of the projector casing apart.
終わりに
Winthrop Townsend
メンバー登録日: 2015年01月08日
278 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S18G3
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 74
