メインコンテンツにスキップ
Merch Source Projector Entertainment II Light Bulb Replacement
必要な工具と部品
  1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: 手順 1、 2の画像 1 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: 手順 1、 2の画像 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Light Bulb Replacement: 手順 2、 1の画像 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Light Bulb Replacement: 手順 3、 2の画像 1 Merch Source Projector Entertainment II Light Bulb Replacement: 手順 3、 2の画像 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: 手順 4、 3の画像 1 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: 手順 4、 3の画像 2 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: 手順 4、 3の画像 3
    • Remove the light bulb from its housing unit.
    • Do not damage the 2 white cables leading into the light bulb panel.
  5. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: 手順 5、 2の画像 1 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: 手順 5、 2の画像 2
    • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
    • The light blub is held into the socket with prongs, and should easily pull straight out.
    What light bulb do I need?
    ingadewitt606 - 返信
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Stephanie
メンバー登録日: 01/08/15
276 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S18G3
3 メンバー
4のガイドは作成済み
コメント 1 件
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 1,826
