メインコンテンツにスキップ
Mercedes W123 Wheel Removal Technique
必要な工具と部品
  1. Mercedes W123 Wheel Removal Technique, Mercedes W123 Wheel Removal Technique: 手順 1、 3の画像 1 Mercedes W123 Wheel Removal Technique, Mercedes W123 Wheel Removal Technique: 手順 1、 3の画像 2 Mercedes W123 Wheel Removal Technique, Mercedes W123 Wheel Removal Technique: 手順 1、 3の画像 3
    • Start with your vehicle's wheels flat on level ground.
    • Grab your trusty lug wrench.
    • Place it on one of your lug bolts. Note I say bolt, not lug nut. This will be explained later.
    • Yank on the lug wrench, it may take a lot of force to break the lug bolt loose!
    • If you need some extra force use your leg, or even stand on the lug wrench being careful to keep your balance. This should break it free.
  2. Mercedes W123 Wheel Removal Technique: 手順 2、 1の画像 1
    • Repeat the previous step on all five lug bolts, on each of the wheels you plan to remove. This loosens them, but do not remove them yet.
    • Now, you'll jack up whichever end(s) of the vehicle you plan to work on.
    • If you need guidance on this see the jacking technique guide.
  3. Mercedes W123 Wheel Removal Technique: 手順 3、 2の画像 1 Mercedes W123 Wheel Removal Technique: 手順 3、 2の画像 2
    • Continue to loosen each lug bolt until they can be removed.
    • You can see here the lug bolt. This will be different than the lug nuts you may be used to on other vehicles.
  4. Mercedes W123 Wheel Removal Technique: 手順 4、 1の画像 1
    • You can now remove the wheel. Shown here is the rear wheel removed, exposing the brake disc.
    • Notice the lip of the hub exposed here. This will allow you to rest the wheel on the hub so you do not have to hold up its weight while getting the lug bolts back in during re-install.
  5. Mercedes W123 Wheel Removal Technique: 手順 5、 1の画像 1
    • Re-install is basically the opposite of removal. However, as you tighten up the lug nuts, there are a few tips:
    • Tighten them in a "star" patter, rather than in a circular pattern. This ensure more even tightening.
    • Lower the car once they are snug so the tires are on the ground.
    • Finish tightening them with a torque wrench to ensure they are on tight enough. Your owner's manual should specify the tightness required.
終わりに
Take a test drive. Then re-check the torque on all the lugs you removed.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Nicolas Siemsen
メンバー登録日: 12/06/13
38,854 ポイント
79のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
320 メンバー
1,357のガイドは作成済み
2 件のコメント
How dumb does not advise if it is right or left hand thread Bolt.
George Spiteri - 返信
Very informative but forgot the most important detail. Is this a left hand or right hand thread?
George Spiteri - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 24
今までの合計 10,374
