この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
For such a small and inexpensive part the sway bar link on the rear suspension of W123's can create quite the racket.
If, as you drive or rough roads, you hear a lot of rumbling or clunking from the rear of the car the first place to check is the sway bar links. It's easy to diagnose, and almost as easy to replace. Do yours today; stop living with the noise!
必要な工具と部品
You will need to begin by jacking up the rear end of your car, and removing the rear wheels. If you need help with these, see the guides below:
Remove the nut from the top of the sway bar link using a 17 mm socket to turn off the nut while holding the inside of the sway bar link joint with an open end 17mm wrench.
Then use the open end 17mm wrench to loosen the bottom joint of the sway bar from the hub assembly.
You'll then be able to remove the sway bar link for inspection. Save the nut and any washers as the new links do not come with replacements.
9 の人々がこのガイドを完成させました。
3 件のコメント
Great photos and videos. Good job. Thanks.
Pat OBrien - 返信
You're welcome! This is definitely one of those repairs that are 1) easy and 2) provide a LOT of immediate tangible benefit. It's super annoying driving around with bad sway bar links.
