メインコンテンツにスキップ
Mercedes W123 Radiator Hose Replacement
必要な工具と部品
  1. Mercedes W123 Radiator Hose Replacement, Radiator Hose: 手順 1、 1の画像 1
    • Begin by draining your radiator of coolant as [無効なガイドリンク]. You will not need to drain the block for this process.
    • As always, never work on your coolant system when it is hot. This is very very dangerous.
  2. Mercedes W123 Radiator Hose Replacement: 手順 2、 2の画像 1 Mercedes W123 Radiator Hose Replacement: 手順 2、 2の画像 2
    • Find your upper coolant hose connection at the upper driver's side of the radiator.
    • Loosen the hose clamp on this end of the hose.
  3. Mercedes W123 Radiator Hose Replacement: 手順 3、 1の画像 1
    • Follow this hose to the top of the engine block, where it enters the thermostat housing.
  4. Mercedes W123 Radiator Hose Replacement: 手順 4、 1の画像 1
    • Then use a hose clamp removal hook or other appropriate tools to work around under the edge of the hose. This will help break them free; they often stick to the necks they attach to over time.
    • Pull the hose off fully on both ends.
  5. Mercedes W123 Radiator Hose Replacement: 手順 5、 1の画像 1
    • Continue by loosening the clamp on the lower radiator hose where it connects to the thermostat housing.
  6. Mercedes W123 Radiator Hose Replacement: 手順 6、 1の画像 1
    • Then go underneath the car and loosen the clamp on the lower radiator hose where it connects to the radiator.
    • Remove the hose in the same manner you did the upper hose.
    • Now replace both hoses, and secure with hose clamps. Replace the hose clamps with new ones if they were difficult to open due to corrosion or stripped screw heads.
    • Finish by filling the system with coolant and bleeding the system as [無効なガイドリンク]
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Nicolas Siemsen
メンバー登録日: 12/06/13
38,854 ポイント
79のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
320 メンバー
1,357のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 6,161
