メインコンテンツにスキップ
Mercedes W123 Fuel Return Line Replacement
必要な工具と部品
  1. Mercedes W123 Fuel Return Line Replacement, Fuel Return Line: 手順 1、 3の画像 1 Mercedes W123 Fuel Return Line Replacement, Fuel Return Line: 手順 1、 3の画像 2 Mercedes W123 Fuel Return Line Replacement, Fuel Return Line: 手順 1、 3の画像 3
    • As shown here, the injector return lines go from one injector to the next.
    • And then they stop with a plug at the rearmost injector, closest to the firewall.
  2. Mercedes W123 Fuel Return Line Replacement: 手順 2、 1の画像 1
    • The lines should simply pull off of the injector nipples.
    • These lines were fairly stiff, but not brittle yet. However, it's a good time to replace them. Once they become brittle the can become very hard to remove. They will break off at the nipple and they will need to be cut off with a razor blade, very carefully, to avoid scoring the metal nipples.
  3. Mercedes W123 Fuel Return Line Replacement: 手順 3、 1の画像 1
    • Notice how much larger the opening at the end of the old injector return line, left, is than the one on the right, which is new.
    • As the lines become brittle they seal less well at the nipples due to this.
    • Now, cut a length of new line to approximately the same length as the old line. You can err on the side of being a bit too long to make it easier to install.
    Would be very helpful to call out the fuel line sizing & SAE coding. I just ordered this kit on Amazon, no expectations around quality or longevity: https://www.amazon.com/dp/B07L6SS6B6?
    Joe Smith - 返信
  4. Mercedes W123 Fuel Return Line Replacement: 手順 4、 2の画像 1 Mercedes W123 Fuel Return Line Replacement: 手順 4、 2の画像 2
    • Installation is simply the reverse; push the new line down on to the nipples on the injector.
    • It can help to do just one at a time, so you don't mix up which line goes where.
    • Another helpful tip is to use a small needle nose plier to start the line on the injector nipple when the space if too tight for your fingers.
  5. Mercedes W123 Fuel Return Line Replacement: 手順 5、 2の画像 1 Mercedes W123 Fuel Return Line Replacement: 手順 5、 2の画像 2
    • Don't forget to replace the long piece of line that runs from the front-most injector to the secondary fuel filter housing.
    • It starts here at the front-most injector.
    • And connects here at the filter housing.
  6. Mercedes W123 Fuel Return Line Replacement: 手順 6、 3の画像 1 Mercedes W123 Fuel Return Line Replacement: 手順 6、 3の画像 2 Mercedes W123 Fuel Return Line Replacement: 手順 6、 3の画像 3
    • Also, be sure to change the plug on the rear-most injector nipple.
    • The one removed from this car was a braided line with a metal plug in it.
    • The one being installed is a special rubber plug that only has one opening.
    • You can also make one yourself, using a short piece of regular return line and a tightly fitting screw that can be securely inserted in one end of the short line.
    Mercedessource.com makes a tool that makes this job so much easier and may be used for other jobs as well . Lol I'm a regular customer of Kent's because I'm rebuilding an 83 300D Tubro , my 3rd one . I just love this site and Kent's . I recently took my old girl in to have someone else do some work while I recovered from surgery , well in two days the fuel injectors were leaking .$1400 down the drain ..They used the wrong fuel lines. I'll be replacing them myself. Along with a fuel shut off switch,kickdown switch, vcv & erg valve ,and the fixing the door vacuum lines that they have turned into their self ,so please keep the information coming ! Thank you , Blade
    Catherine - 返信
終わりに
Once you're done priming, start the engine and let it run momentarily to ensure it's primed properly.
11 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Nicolas Siemsen
メンバー登録日: 12/06/13
39,040 ポイント
79のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,528のガイドは作成済み
3 件のコメント
What size diameter and fuel line material should I get as a replacement?
Simon Walter-Hansen - 返信
The lines are available in Viton as well, which is biodiesel compatible:
617/616: https://www.amazon.com/dp/B07L6SS6B6
603/602/601: https://www.amazon.com/dp/B07L6QTYS1
Will MacNeill - 返信
I redid my lines after paying a shop here in Granbury,TX 1400.00 to replace my fuel injection system..thier tech told me when I picked my 83 Benz 300D Turbo up..that he had no idea what he was doing..after the fact..he put plain rubber hoses on her that melted on the way home.. I'm a 60 yr old female whose worked on cars for 50yrs, never have I seen such poor service..as this shop.
Catherine - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 71
今までの合計 16,275
