メインコンテンツにスキップ
Mercedes W123 Front Seat Back Netting Repair
必要な工具と部品
  1. Mercedes W123 Front Seat Back Netting Repair, Remove Seat Back: 手順 1、 2の画像 1 Mercedes W123 Front Seat Back Netting Repair, Remove Seat Back: 手順 1、 2の画像 2
    • Start by turning the seat angle adjusting knob clockwise so that the seat is leaning all the way forward. This is necessary for clearance.
    • Using a phillips head screwdriver, loosen the single screw holding the seat back at the bottom of the seat.
    • Remove the seat back by sliding it downwards towards the floor. Once it is approximately 50-70% down, it should clear its tracks with enough space to facilitate removal by pulling down and towards the rear seat. It should come out very easily.
  2. Mercedes W123 Front Seat Back Netting Repair, Disassemble Seat Back: 手順 2、 3の画像 1 Mercedes W123 Front Seat Back Netting Repair, Disassemble Seat Back: 手順 2、 3の画像 2 Mercedes W123 Front Seat Back Netting Repair, Disassemble Seat Back: 手順 2、 3の画像 3
    • Unscrew the two phillips head screws on the back of the seat back. These hold the plastic netting trim into place.
    • Once the screws are removed, the plastic trim is still retained by a system of clips. To loosen the clips, slide the trim "up" to relieve all but the two bottom center clips, then left/right to relieve the bottom center clips. At this point, the plastic trim is free of the seat back.
    • Now, remove the old bungee from its retaining clips. It should come out quite easily. Remove the old bungee from the seat back netting.
  3. Mercedes W123 Front Seat Back Netting Repair, Replace Bungee: 手順 3、 3の画像 1 Mercedes W123 Front Seat Back Netting Repair, Replace Bungee: 手順 3、 3の画像 2 Mercedes W123 Front Seat Back Netting Repair, Replace Bungee: 手順 3、 3の画像 3
    • Procure some bungee cord. You will want ~4 mm bungee cord which can be bought online or at some home improvement stores. In my case, I was able to salvage some from a kayak deck rigging kit.
    • Cut the bungee cord to length. Approximately 16 inches seems to be a good length. You want the bungee to be slightly taught in the natural resting position. A good rule of thumb is that it should be just short of the width between its mounting points.
    • The old bungee cord used crimped metal to retain the bungee in its clips. I didn't have this readily available, so I melted the ends of the bungee slightly to mushroom the ends out a little bit, then installed a thin zip tie to accomplish the same thing.
    • You will have to stretch the bungee to clip it in to the other side, and this will temporarily deform the plastic trim until it is reinstalled into the seat back.
  4. Mercedes W123 Front Seat Back Netting Repair, Reassemble Seat Back and Reinstall: 手順 4、 2の画像 1 Mercedes W123 Front Seat Back Netting Repair, Reassemble Seat Back and Reinstall: 手順 4、 2の画像 2
    • Remember the trick about how the clips go--we're doing it in reverse now. First engage the bottom center clips (shown top in this image) in their top most position, then engage the side clips by pushing the plastic trim piece down.
    • Don't forget to reinstall the two phillips head screws that retain the trim piece.
    • With the seat in the car still all the way forward, you should be able to easily engage the seat back into its tracks, pushing it up until you can engage the screw at the bottom. Enjoy your restored seat back netting!
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Wes Brown
メンバー登録日: 09/09/16
201 ポイント
1ガイドが承認済み
コメント 1 件
Wo bekommt man diese schwarzen Netze, wenn sie, wie bei mir, gerissen sind? Reparieren kann man diese Netze nicht wirklich? Hat jemand eine Lösung ?
Peter - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 58
今までの合計 5,121
