この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Diesel oil is specially designed to hold diesel soot in suspension within the oil to keep it from clogging oil passages, building up on cylinder walls, etc. If left in the engine for too many miles it will become full of soot and won't be able to suspend it any longer.
For this reason you'll want to change your oil pretty religiously. Some people extend their change intervals to 5,000 miles when using synthetic oil. When using conventional oil it should be changed every 3,000 miles.
Change your filter while you are at it.
As always be careful when handling automotive fluids. Diesel oil, as it is filled with diesel soot, will stain your driveway, your clothes, your skin, and anything else it touches. Wear gloves.
Be sure to also catch the fluid in the proper container and dispose of it properly. Almost every auto parts store will accept used oil and oil filters for proper disposal.
Note that this is just one of two methods. This method has you under the car, removing the drain bolt. Another method is to use a suction device to draw engine oil up and out of the dipstick. The filter change process is the same, regardless of the oil change method used.
必要な工具と部品
To start, remove the oil cap. This will allow the oil to drain out of the engine faster.
Once the nuts are loosened and removed, lift the cover up and out of the filter housing. Remove the filter as well.
Be careful as you remove the cover. It can be easy to disconnect some of the vacuum lines that cross over and next to the oil filter housing. If this happens you may cause issues with the vacuum system such as the locks, the shut-off valve, or transmission.
Note that when you remove the oil filter, the bit of oil left in the housing will then drain from the drain plug. Make sure to leave the drain pan underneath until you re-install the drain plug towards the end of the guide.
The new oil filter kit should come with the filter itself, a choice of new crush washers for the drain plug bolt, and a new large o-ring gasket for the oil filter housing cover.
It's generally recommended to use the copper crush washer. Copper is a soft metal that crushes well for a good seal.
Check the o-rings at the tip of the oil filter housing shaft. There are two of them. If they are hardened, or no longer round, they should be replaced. Proper o-rings can be found in any metric o-ring set.
It is good practice to replace these every third or fourth oil change as preventative maintenance.
The ones shown here are very flat, and brittle. They had to be broken off as all of their elasticity was gone. They had been neglected for some time, and they were doing little good as a seal.
It's time to put in fresh oil. Use a diesel rated oil.
Consult your owner's manual for what viscosity to use based on your climate. Where this car is located, 15w40 works year round but a thinner oil such as 0w40 could be helpful for cold starts in very cold climates.
Start by putting in about 5 or 5 and 1/2 quarts. Wait a few minutes to let it run down to the oil sump. Then put the oil cap on and start the engine. Make sure oil pressure shows on the gauge fairly quickly. Then let it run for about 1 minute. This will fill the filter housing back up with oil.
Then turn off the car and check the oil level. If it's low, add no more than 1/2 quart at a time until it's full. It will take between 6 and 6 and 1/2 quarts. If you want some guidance on checking oil level see the oil level check guide.
Be sure to check for leaks after you've taken a short test drive.
32 の人々がこのガイドを完成させました。
3 件のコメント
Judging by the listed oil capacity, I'm guessing that the vehicle in the guide has an OM616. What starting / final oil capacity would you suggest for an OM617A (oil-cooled turbo)? I've been quoted 7.8qts before.
Actually, this is a OM671a. The 7.8 qt capacity is the original fill capacity when the engine is filled at the factory.
When changing the oil, you're going to be between 6 and 7 quarts for re-fill as a certain amount of oil (approx a quart) remains in the oil cooler unless you remove the lower oil cooler hose each time you change the oil, which is not generally recommended.
I prefer not to give a specific fill capacity as the better method is to first slightly underfill, then run the engine and check the level before topping off. This ensures that you do not overfill the engine. Being under-filled is less of an issue by far than overfill. Overfill can cause foaming and even a runaway diesel in extreme cases.
