メインコンテンツにスキップ
Mercedes W123 Diesel Fuel Filter, Primary Replacement
必要な工具と部品
  1. Mercedes W123 Diesel Fuel Filter, Primary Replacement, Fuel Filter, Primary: 手順 1、 1の画像 1
    • Here is your clear fuel primary filter. It is located directly next to the fuel primer pump.
  2. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 手順 2、 1の画像 1
    • Begin by loosening this hose clamp, at the top of the primary filter, nearest the engine.
    • Pull the primary filter up and out of this hose. A small amount of fuel will leak out, consider putting a towel, plastic bag, or other appropriate catch underneath.
  3. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 手順 3、 1の画像 1
    • Now loosen the clamp on the bottom of the primary filter, further from the engine.
    • You will now be able to pull the filter out the rest of the way. The fuel in it will drain out, catch it with towel or something similar.
  4. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 手順 4、 1の画像 1
    • Here is the old primary filter, removed from the car. Note the large chunks of debris in the filter.
  5. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 手順 5、 1の画像 1
    • You can see here the new primary filter. Note that the filter is usually marked with an arrow noting the direction of fuel flow. It should be installed with this arrow pointing towards the engine.
  6. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 手順 6、 1の画像 1
    • Install the new filter by retracing the steps so far, just backwards.
    • This is a good time to consider replacing the large secondary filter. If you would like guidance on this, see the secondary fuel filter replacement guide.
    • Then, pump the primer pump on the car until the primary filter fills with fuel. It's normal for there to be a small air bubble in the primary filter but it should be mostly clear.
終わりに
When finished, run the engine to ensure it's been primed properly.
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nicolas Siemsen
メンバー登録日: 12/06/13
39,040 ポイント
79のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,528のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 16
過去 30 日: 79
今までの合計 16,746
