メインコンテンツにスキップ
Mercedes W123 Battery Ground Cable Replacement
必要な工具と部品
  1. Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: 手順 1、 2の画像 1 Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: 手順 1、 2の画像 2
    • Start by disconnecting both battery terminals, beginning with the negative (-) side, which travels just a few inches to a bolt attaching the other end to the car's body.
    • Never remove your positive (+) cable first or you risk injury from electric shock.
  2. Mercedes W123 Battery Ground Cable Replacement, Remove the old ground cable: 手順 2、 1の画像 1
    • Loosen and remove this 13mm bolt that holds the cable to the metal of the car's chassis.
    • Now remove the old ground cable.
  3. Mercedes W123 Battery Ground Cable Replacement, Install the new cable: 手順 3、 2の画像 1 Mercedes W123 Battery Ground Cable Replacement, Install the new cable: 手順 3、 2の画像 2
    • You can see here that the new ground cable is substantially thicker. It is a 2 gage cable. The ends are also crimped better, protecting the inner wire from corrosion.
    • This cable is also a bit longer than the old one, giving some more wiggle room.
  4. Mercedes W123 Battery Ground Cable Replacement: 手順 4、 1の画像 1
    • Install the new ground cable, using the new captive bolt, and nut, that came with it.
終わりに
Once you've finished, consider covering the terminal where the cable attaches to the battery in a silicone dielectric grease to prevent corrosion.
12 の人々がこのガイドを完成させました。
Nicolas Siemsen
メンバー登録日: 12/06/13
38,854 ポイント
79のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
320 メンバー
1,357のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 29
今までの合計 8,650
