メインコンテンツにスキップ
Mercedes W114/W115 Cluster Clock replacement and troubleshooting
必要な工具と部品
  1. Mercedes W114/W115 Cluster Clock replacement and troubleshooting, Cluster Clock: 手順 1、 2の画像 1 Mercedes W114/W115 Cluster Clock replacement and troubleshooting, Cluster Clock: 手順 1、 2の画像 2
    • Locate the area that houses the clock. Unscrew the two barrels and place it aside.
    • Carefully pull out the clock without damaging any other parts.
  2. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 2、 3の画像 1 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 2、 3の画像 2 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 2、 3の画像 3
    • Connect the screw (located behind the clock) to the negative supply of the battery, and then the small pin to the positive supply.
  3. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 3、 3の画像 1 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 3、 3の画像 2 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 3、 3の画像 3
    • To check the clock, set the time to something you can remember and set it aside.
  4. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 4、 3の画像 1 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 4、 3の画像 2 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 4、 3の画像 3
    • To check the power supply of the clock, locate the electrical connector and find the pin on it which supplies the power (12v) to the clock.
    • Take a small bulb and socket and bridge a wire from the 12v pin supplied from the electrical connector, to one of the two wires on the bulb and socket.
    • Next find a ground supply nearby ( the best place would be the key hole) and bridge another wire from it to the second available wire on the bulb and socket.
    • If the bulb lights up, it means your clock has power.
  5. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 5、 2の画像 1 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 5、 2の画像 2
    • If the bulb lights up, the power supply to the clock is good.
  6. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 手順 6、 1の画像 1
    • Before putting the clock in, clean the holder with a sand paper or a flat headed screw driver.
    • Start reassembling the dashboard by following the guide in reverse order.
    • While reassembling, be careful not to damage the wire harness , oil pressure meter hose, and temperature meter cable.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Chaga Edirisinghe
メンバー登録日: 02/20/14
301 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 25
今までの合計 6,464
