はじめに
The computer comes with a minimum of 2 GB of memory, installed as a pair of 1 GB fully buffered, dual inline memory modules (FB-DIMMs) in two of the DIMM slots. This procedure will show you how to add more memory or remove the memory riser for maintenance.
ツール
パーツ
パーツは指定されていません。
Shut down the computer.
Wait 5 to 10 minutes to allow the computer’s internal components to cool.
Unplug all external cables from the computer except the power cord.
Touch the metal PCI access covers on the back of the computer to discharge any static electricity from your body.
Unplug the power cord.
Put on an ESD wrist strap.
800 MHz, DDR2, FB-DIMMS
72-bit wide, 240-pin modules
36 memory ICs maximum per DIMM
Error-correcting code (ECC)
10 の人々がこのガイドを完成させました。
