この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The steps in this guide will instruct you on how to disassemble the boombox and remove the speakers. In the guide, we focus on removing the left speaker, but the instructions given are also applicable to the right speaker. Extensive disassembly and very basic soldering is required. The environment preferred is a clear worktable space.
必要な工具と部品
Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
Use a Phillips #1 screwdriver to unscrew the two 8 mm screws on the speaker housing.
4 の人々がこのガイドを完成させました。
