はじめに
If these microswitches on the drive do not work precisely, the machine will not work properly and the drive may be damaged. Replacing the Cherry D41X microswitches is not very difficult.
Note: you can also open the drive without unscrewing it completely. Then skip the corresponding steps.
必要な工具と部品
Remove the water tank and drainage tray.
Remove the side cover and remove the brewing unit.
Remove all coffee beans.
Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
Open the cover over the drive. It is held by latches.
Remove the cover.
The two microswitches are exposed.
Follow the the steps in reverse order to reassemble your device.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
