必要な工具と部品
Remove the hose connecting the upper piston and the coffee outlet.
Remove the upper piston.
Remove the Torx T20 screw from the screen of the upper piston.
Take off the cover of the gasket and the gasket.
Replace the gaskets of the upper piston, the coffee outlet and water connector.
Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
Follow the steps in reverse order to reassemble your device.
11 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
The brewing unit in my Melitta Avanza Series 600 (which is apparently identical) was completely stuck inside the machine, and the only way I could get it out was to follow this guide. Unscrewing the accessible side of the brewing unit gave me the necessary access to finally get the brewing unit unstuck and out of the machine. The cap mentioned in step 2 was a bit hard to get out with the brewing unit still inside the machine, but by first unscrewing all the other screws to loosen the side a bit and then using some force, I finally got it off without breaking it.
Note that I also had to reset the main gear position to get the brewing unit back into the machine, which on my machine was performed by pressing the single + double espresso front panel buttons for 2 seconds.
The reason why it was stuck? 100% my fault. I turned the machine off in the middle of a cleaning cycle when I realised I forgot to insert a cleaning tablet, and then tried to get the brewing unit out and ... yeah ... don't be an idiot like I was, do NOT attempt to take the brewing unit out while it's in "engaged" mode, unless you too wish to follow this guide for that reason. 😉
Fixiepixer - 返信
There is also a more bloodless way: open the left side, find the cables to the motor. Connect 12 V DC, et voila....
VauWeh -
