メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Meizu MX3 Rear Facing Camera Replacement
必要な工具と部品
    1. Meizu MX3 Rear Facing Camera Replacement, Removing the Back Cover: 手順 1、 3の画像 1 Meizu MX3 Rear Facing Camera Replacement, Removing the Back Cover: 手順 1、 3の画像 2 Meizu MX3 Rear Facing Camera Replacement, Removing the Back Cover: 手順 1、 3の画像 3
      • Insert the plastic opening tool in between the charging port and the back case of the device. Slowly move the tool to the left of the until you come the top by the power button.
      • Using a paper clip or pointed edge spudger push in the pin located in the bottom right had corner of the back of the phone.
      FixBotに聞いてみる
      コメントを追加
    2. Meizu MX3 Rear Facing Camera Replacement, Removing the Screws in the Internal Casing: 手順 2、 3の画像 1 Meizu MX3 Rear Facing Camera Replacement, Removing the Screws in the Internal Casing: 手順 2、 3の画像 2 Meizu MX3 Rear Facing Camera Replacement, Removing the Screws in the Internal Casing: 手順 2、 3の画像 3
      • Using one of the small Phillips screwdriver bits provided unscrew the 11 screws present on the protective plastic plate under the device case.
      FixBotに聞いてみる
      コメントを追加
    3. Meizu MX3 Rear Facing Camera Replacement, Removing the Battery: 手順 3、 3の画像 1 Meizu MX3 Rear Facing Camera Replacement, Removing the Battery: 手順 3、 3の画像 2 Meizu MX3 Rear Facing Camera Replacement, Removing the Battery: 手順 3、 3の画像 3
      • After the 11 screws are loosened use the plastic opening tool and gently pry the protective plate from the back of the device.
      • Once the plate is off, use the same tool to gently remove the 3 ribbon cables located directly above the battery.
      • Potential for device damage: On the left side of the battery on the phone case, there is a groove where the plastic opening tool can be inserted to pry the battery up and out. The battery might be glued to the phone so exercise caution.
      FixBotに聞いてみる
      コメントを追加
    4. Meizu MX3 Rear Facing Camera Replacement, Removing Extra Components: 手順 4、 3の画像 1 Meizu MX3 Rear Facing Camera Replacement, Removing Extra Components: 手順 4、 3の画像 2 Meizu MX3 Rear Facing Camera Replacement, Removing Extra Components: 手順 4、 3の画像 3
      この手順で使用する道具:
      • Remove the screws in the three red circles.
      • Two of the three ribbon cables in the orange box will need to be removed like those above the battery. Use the pointed edge spudger to pull the third cable out to the left.
      • Insert the plastic opening tool on top the ribbon cable but below the circuit board in the yellow circle, and pry that ribbon cable free. Remove the headphone jack as see in the picture.
      • Use tweezers to disconnect the wire connector in the green box. As seen in the picture gentle insert the plastic opening tool and unhook that cable and begin to lift the circuit board.
      FixBotに聞いてみる
      コメントを追加
    5. Meizu MX3 Rear Facing Camera Replacement, Removing the Camera: 手順 5、 3の画像 1 Meizu MX3 Rear Facing Camera Replacement, Removing the Camera: 手順 5、 3の画像 2 Meizu MX3 Rear Facing Camera Replacement, Removing the Camera: 手順 5、 3の画像 3
      • Use the pointed edge spudger, remove the cable in the box by prying the left side and right side of the cable repeatedly. Then remove the camera.
      • Once the camera is removed, the circuit board should look like the board in the last picture.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Mandela Robin
メンバー登録日: 09/23/14
876 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 15-2, Remmell Fall 2014 USF Tampa, Team 15-2, Remmell Fall 2014人のメンバー
USFT-REMMELL-F14S15G2
4 メンバー
27のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 1,332
