メインコンテンツにスキップ
Maylong M-295 Motherboard Replacement
必要な工具と部品
  1. Maylong M-295 Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Use a PH 00 Phillips head screwdriver to remove the screws from the bottom of the tablet.
  2. Maylong M-295 Motherboard Replacement: 手順 2、 2の画像 1 Maylong M-295 Motherboard Replacement: 手順 2、 2の画像 2
    • Caution: Before completely removing the cover take note of the wires connecting the speaker to the motherboard. Do not pull off the cover too forcefully or else the wires will become unsoldered from the motherboard. (Refer to picture 1)
    • Use a plastic pry tool to gently pry open the tablet by inserting the plier in between the pink back cover and black screen frame.
    • Be sure to go around all corners of the tablet carefully.
    • You may need insert a second pry tool close to the first to keep the cover from closing as you move around the edges.
  3. Maylong M-295 Motherboard Replacement: 手順 3、 1の画像 1
    • Slowly flip open the pink back cover and gently remove the speakers from it with a plastic plier.
  4. Maylong M-295 Motherboard Replacement: 手順 4、 2の画像 1 Maylong M-295 Motherboard Replacement: 手順 4、 2の画像 2
    • Use a PH 00 Phillips head screwdriver to remove the seven screws from around the perimeter of the interior screen frame.
    • 3 screws are located on the bottom of the motherboard (as indicated in picture 1)
    • 4 screws are located in brackets around the silver screen plate (as indicated in picture 2).
    • Note: The brackets (small black plastic pieces) will become loose when the screws are taken out and then can easily be removed.
  5. Maylong M-295 Motherboard Replacement: 手順 5、 1の画像 1
    • Unsolder wires that are connected to the motherboard by pressing the solder tool to the flux and liquifying it. Then the wire can easily be pulled away from the motherboard.
  6. Maylong M-295 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove motherboard by pulling up and out from the body of the tablet.
終わりに
作成者
3人の作成者と共同で作成されました。
Sali Kamara
メンバー登録日: 09/30/15
64 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 2-4, Garvin Fall 2015 Ohio State, Team 2-4, Garvin Fall 2015人のメンバー
OSU-GARVIN-F15S2G4
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 170
