メインコンテンツにスキップ
MaxWest TAB-7360DC Motherboard Replacement
必要な工具と部品
  1. MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: 手順 1、 3の画像 1 MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: 手順 1、 3の画像 2 MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: 手順 1、 3の画像 3
    • Insert plastic opening tool at the corner of the screen, in between the back case and the front.
    • Volume buttons will fall out during removal.
    • When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
  2. MaxWest TAB-7360DC Motherboard Replacement: 手順 2、 2の画像 1 MaxWest TAB-7360DC Motherboard Replacement: 手順 2、 2の画像 2
    • Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
    • The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
  3. MaxWest TAB-7360DC Motherboard Replacement: 手順 3、 1の画像 1
    • Gently unclip the data cable retainers and remove the wires from the junctions.
    • Peel the tape off the wire near the bottom of the case.
  4. MaxWest TAB-7360DC Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the two 4mm screws (circled in orange) with a 00 Phillips head driver.
    • Unclip the black plastic retainer near the data port. The PCB should now be able to be gently pulled off.
  5. MaxWest TAB-7360DC Motherboard Replacement: 手順 5、 1の画像 1
    • Make contact with the battery terminals with the hot tip of the soldering iron for a few seconds while slowly pulling the wire away.
    • DO NOT TOUCH BOTH THE BLACK AND RED LEADS AT THE SAME TIME WITH THE SOLDERING IRON
  6. MaxWest TAB-7360DC Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 MaxWest TAB-7360DC Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • With the tweezers, grab onto the gray part of the ribbon clamps and pull away from the ribbons.
    • Once the ribbons are unclamped, they are able to slide out.
終わりに
作成者
2人の作成者と共同で作成されました。
Clint Crabb
メンバー登録日: 03/26/18
115 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S4-G3, Baechle Spring 2018 IUPUI, Team S4-G3, Baechle Spring 2018人のメンバー
IUPUI-BAECHLE-S18S4G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 222
