メインコンテンツにスキップ
Mavic 2 Controller Joystick Replacement
必要な工具と部品
  1. Mavic 2 Controller Joystick Replacement, Controller Joystick: 手順 1、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 5.7 mm screws from the bottom of the controller.
  2. Mavic 2 Controller Joystick Replacement: 手順 2、 2の画像 1 Mavic 2 Controller Joystick Replacement: 手順 2、 2の画像 2
    • Insert the opening tool to separate the small plastic part from the main housing of the controller that was unscrewed in the last part.
    • Remove the remaining plastic cover by unclipping the tabs located next to the charging port. Detach the clips that are below the screen that are holding the plastic part in place.
    • Now you should be able to pull out the bottom cover piece.
  3. Mavic 2 Controller Joystick Replacement: 手順 3、 3の画像 1 Mavic 2 Controller Joystick Replacement: 手順 3、 3の画像 2 Mavic 2 Controller Joystick Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    • Use a Phillips #0 screwdriver to remove the two 5.7 mm screws that are secure the top cover.
    • Remove the cable connecting the joystick to the board with a pair of tweezers.
    • There is a cable on both sides, so get both.
    • Go around the top cover, undoing all clips holding the top cover on. Insert the opening tool in between the top cover and the lower base of the controller.
  4. Mavic 2 Controller Joystick Replacement: 手順 4、 2の画像 1 Mavic 2 Controller Joystick Replacement: 手順 4、 2の画像 2
    • Now that the top cover is removed flip it over and you will see something similar to picture one.
    • You will need to use the Phillip #0 to remove the four screws holding the joystick to the top cover plate.
    • This will allow you to replace the joystick with a new one.
終わりに
作成者
2人の作成者と共同で作成されました。
Quentin Rodriguez
メンバー登録日: 11/09/23
115 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 2-3, Harley Fall 2023 IUPUI, Team 2-3, Harley Fall 2023人のメンバー
IUPUI-HARLEY-F23S2G3
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 284
