メインコンテンツにスキップ
Matsunichi MarquisPad MP977 Front Facing Camera Replacement
必要な工具と部品
  1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement, Front Facing Camera: 手順 1、 1の画像 1
    • Using the PH #00 Phillips head screwdriver, unscrew the two screws.
  2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 2、 3の画像 1 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 2、 3の画像 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 2、 3の画像 3
    • Place the device face down on a flat surface.
    • Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 3、 2の画像 1 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 3、 2の画像 2
    • Insert the opening tool into the slot located to the right of the speaker, at the top edge of the device.
    • Then, pry open the back plate of the device , and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 4、 1の画像 1
    • Remove the back plate and place it to the side of the device.
  5. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 5、 1の画像 1
    • With the same screw driver, PH #00 Phillips head, remove the seven screws holding in the motherboard.
    • Place the screws somewhere safe where they wont fall.
  6. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 6、 2の画像 1 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 6、 2の画像 2
    • Gently pull the camera optic fiber out of it's slot to release the flap. This will allow the flap to open easily.
    • Be sure not to damage the camera port.
  7. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 7、 2の画像 1 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 手順 7、 2の画像 2
    • Last, Insert the new camera into the pinhole camera slot.
終わりに
作成者
11人の作成者と共同で作成されました。
Kathryn Sherlock
メンバー登録日: 03/24/15
127 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015人のメンバー
UMASSD-VIJAYBHASKAR-S15S4G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 240
