はじめに
This is a guide to remove the Camera for the Matsunichi M97 9in tablet. To use this guide you will need a spudger, or an iFixit opening tool, a Phillips 00 Screwdriver, and tweezers. This guide requires the Battery Removal Guide, and the Motherboard Removal Guide as prerequisites.
必要な工具と部品
Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
Use the same screwdriver to remove the single 4mm screw.
もう少しです!
終わりに
