メインコンテンツにスキップ
Marvel iHome MR-M66 Auxiliary Port Replacement
必要な工具と部品
  1. Marvel iHome MR-M66 Auxiliary Port Replacement, Back Cover: 手順 1、 2の画像 1 Marvel iHome MR-M66 Auxiliary Port Replacement, Back Cover: 手順 1、 2の画像 2
    • Remove two of the three screws shown on the bottom of the device.
    • Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
  2. Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 2、 3の画像 1 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 2、 3の画像 2 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 2、 3の画像 3
    • Remove the bottom cover by either pulling on the screw or using a plastic opening tool to pry the cover off.
    • After removing the bottom cover, remove the two screws.
  3. Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 3、 3の画像 1 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 3、 3の画像 2 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 3、 3の画像 3
    • Use a spudger to release the small retaining clip that holds the feet to the bottom of the device.
    • Be careful here, as too much force can break the clip.
    • Remove the two screws from the back of the device.
  4. Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 4、 3の画像 1 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 4、 3の画像 2 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 4、 3の画像 3
    • Using a plastic opening tool and your hand, separate the front and back covers from each other.
    • Starting from the bottom, use the plastic opening tool to create the initial separation and continue along the seam to the top of the device.
    • This step requires the most time and patience, so be careful.
    • The power switch will most likely come loose during this step and you will hear something rattling inside the device.
  5. Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 5、 3の画像 1 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 5、 3の画像 2 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 5、 3の画像 3
    • Remove the two arms from either side of the device once a significant separation has been created.
    • They are not fixed to the body itself so you should be able to wiggle them free.
    • Continue pulling the back cover off the device.
    • Remove the red cover for the on/off switch from the device.
  6. Marvel iHome MR-M66 Auxiliary Port Replacement, Auxiliary Port: 手順 6、 1の画像 1
    • Remove the two screws shown to access the battery.
  7. Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 7、 2の画像 1 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 7、 2の画像 2
    • Remove the two screws shown to release the circuitboard.
    • Gently remove both the battery and circuitboard.
    • They will be attached together by the battery's wires.
  8. Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 8、 3の画像 1 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 8、 3の画像 2 Marvel iHome MR-M66 Auxiliary Port Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    購入する
    • Locate the auxiliary port on the top side of the circuitboard.
    • On the bottom of the circuitboard, locate the metal pin connecting the auxiliary port to the circuitboard.
    • Use the soldering iron to disconnect the pin.
    • Use a pair of tweezers to remove the old auxiliary port.
    • Place the new auxiliary port in the same spot and solder the port to the circuitboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Tyler Jacob
メンバー登録日: 03/08/17
201 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G3, Botvin Spring 2017 UMass Dartmouth, Team S5-G3, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S5G3
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 94
